09-22-2018, 01:17 PM | #1 |
Busy morning, trunk and chain installed , ect.
I had a busy morning. Started at the crack of dawn to beat the heat. I made the base plate out of 3/32" aluminum plate I had laying around and painted flat black to match the bike. Drilled a few holes and bolted it up.
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 09-24-2018 at 10:10 AM. |
09-22-2018, 01:20 PM | #2 |
Next was installing the o-ring chain. The old one had a couple of damaged links from when I threw the chain a few weeks back.
09-22-2018, 01:25 PM | #3 |
Then I finished up the morning pulling the forks off to change the oil and installed 1" pre-load spacer. I put 230ml of Dex/Merc ATF. It's amazing how nasty the oil got after 6 months. It feels so much firmer.
09-22-2018, 01:29 PM | #4 |
My mission for the afternoon is to install LED lights for brake and turn signal on the trunk as soon as USPS drops them off. I'll post pictures of the install later.
09-22-2018, 03:08 PM | #5 |
Got the wiring done on the bike. I used a 4 wire trailer plug so the trunk will still be removable . Now I'm just waiting on USPS for the LED's.
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 09-24-2018 at 10:19 AM. |
09-22-2018, 07:37 PM | #6 |
I got the LED lights installed and wired up. I'll post a video of them working as soon as it finish uploading.
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 09-22-2018 at 08:12 PM. |
09-24-2018, 10:15 AM | #9 |
I did the same thing. I hot glued all the wires and connectors in place before I put the lens back on. I have room to add a third row on top. I may just do that.
09-24-2018, 05:33 PM | #11 |
I would say at least a case.
09-25-2018, 10:30 PM | #12 |
shoot if the trailer plug is wire right you could add a trailer hitch!!!!!
