Anyone know where to get the tr4 valve stems for the hawk 250????
You already have that on the factory tubes, it's the threaded type. Almost all moto tubes will be TR4.
Google image it, there's so many different stem types for different applications. TR6 is offset. TR13 is rubber coated an so on.
Thanks...it's a tubeless tire...and the rubber is worn so it's tough to tell if it was flat or not..
valve stem |
