Old 08-19-2018, 07:42 PM   #1
koon   koon is offline
Taotao 250 rhino, too stiff..
Looking for someone who has an Idea of where I can purchase adjustable shocks to fit my taotao 250 rhino (200cc).. The shocks that came on the thing are to long or the springs too stiff or both. A 259 lb friend of mine could hardly make the suspension go down when he bounced on it! When I ride it the suspension stays topped out and bangs over bumps.... Anyone have a solution for my problem ? Thanks, Koon67
Old 08-20-2018, 11:22 AM   #2
shocks
see your dealer where you got it from
ABIBABA ATV ETC
Old 08-20-2018, 01:14 PM   #3
Thanks for your time, I will check them out...
Old 08-20-2018, 11:51 AM   #4
SilverBullet51   SilverBullet51 is offline
Do you have the perches adjusted to the fully soft position?
Old 08-20-2018, 01:18 PM   #5
I have one more softer notch left on the front but I think I will need more than that. I will try that first though! The rear is at it softest position.... Thanks for your input...
Old 08-20-2018, 02:41 PM   #6
Mudflap   Mudflap is offline
I bought a pair of fronts from EBay item# 322578000342. Definitely better ride than original but should have bought 375mm instead of 400mm. One has started leaking slightly. Currently looking for a better rear shock.
Old 08-22-2018, 04:54 PM   #7
Thanks, I will check ebay. What brand were they and were they adjustable, let me know what you find for the rear..
Old 08-22-2018, 05:46 PM   #8
They're RFY brand. Adjustable spring preload and air pressure.
Old 08-24-2018, 10:08 AM   #9
zackattack91   zackattack91 is offline
eBay. Measure I. Millimeters from eye hole to eye hole.
2016 Coolster 3150-DX2
atv, shocks, suspension, taotao rhino 250
