Old 08-12-2018, 08:36 PM   #1
Meloman   Meloman is offline
Sticky shifter
My 2018 RX3’s shifter sticks between shifts, especially on downshifts. Normally between shifts the shift lever springs back to a “ready” position so that you can then shift up or down. Mine stays against the stop unless I tap it with my foot and then it releases and springs back. So every downshift is a two and sometimes three tap affair in order to engage the next gear.
I have 400 miles on the bike and it hasn’t improved. CSC says I may have to pull the clutch basket and check the return spring but I was hoping someone else has experienced this problem and found another fix before I tear into the motor.
Old 08-13-2018, 10:48 AM   #2
return spring
I agree with the CSC diagnosis. One other member had an issue with the shift return spring. Yes, it's a PITA to have to fix this on a new machine but the current situation will really detract from enjoying the bike. At least this is covered by your warranty.
It has been a few weeks since I split the cases on my engine but looking at the CSC parts list is appears that the return spring is on the left side. If that's the case you should not have to mess with the clutch side at all, only the left side. Not sure if that makes any difference, it's still a PITA. As usual, Gerry is the guy to ask.
Peter Y.
Old 08-13-2018, 11:16 AM   #3
Juanro   Juanro is offline
Juanro's Avatar
Hi, the return spring is on the right side. You have to remove oil and coolant, take out the water pump and brake pedal, and then the right side cover. Is wouldn't be hard if not for the two rearmost bolts, wich are behind the frame and are a real PITA to remove.
Once with the right side exposed, you remove the gear lever from the axle (on the left side) and then the while gear change axle can be pulled out to the right… it's a fiddly affair if you don't remove the whole clutch housing, but it can be done.
The return spring is a part known by having failed prematurely a number of times.
Regards,
Juanro
Old 08-13-2018, 11:19 AM   #4
Juanro's Avatar
In this video from fellow argentine mechanic Gustavo Galli you can see more detail
(it's in spanish but the image speaks by itself)
Old 08-13-2018, 11:42 AM   #5
sqwert   sqwert is offline
Get it done. One of the really nice things about the RX3 is its transmission, when everything is right. Best and easiest I've ever owned, so it is worth the trouble.
Old 08-14-2018, 07:56 PM   #6
The more I think about it, the return spring should either be working or broken, in which case the shifter wouldn’t spring back at all. So I suspect it must be something else.
I just spoke to Steve (owner of CSC) and he agrees and is looking into it.
Pyoungbl: Gerry is no longer working there. Joey is the new CSC tech. And who is the person you mentioned who had the shifter spring problem ? Did it break or did he have the same symptoms as I’m having ?
Old 08-15-2018, 10:31 AM   #7
Thanks for the update on Gerry. RE the other return spring issue...cannot remember who had the problem, must have been mentioned on this forum since this is the one that seems to cover the RX3 in depth, in that case the spring was broken.
It's comforting to hear that the president/owner of the company is helping you solve the problem.
Peter Y.
Old 08-15-2018, 11:35 PM   #8
Jay In Milpitas's Avatar
Meloman, it wasn't mentioned, but has the bike fallen on it's left side?
If the shift lever or the shaft got bent, it can cause binding.
I suggest trying the shift lever by hand with close observation.
Put the bike on the center stand or up on some maintenance stand to turn the rear wheel by hand while working the shifter. Watch, listen, and feel. This may help to give you an idea where the problem is.
Horse holder at Madame Orr's House.
Old 08-25-2018, 08:22 PM   #9
GSC   GSC is offline
Is this a thing?
I experienced a few times only to discover I was NOT lifting my big foot off the shift lever!
Alls well now
Old 08-25-2018, 09:53 PM   #10
BigDukeSix   BigDukeSix is offline
BigDukeSix's Avatar
Originally Posted by GSC View Post
Is this a thing?
Alls well now
I love it when the solutions are this easy. It's rare, but nice when it goes that way.
Old 08-26-2018, 11:42 PM   #11
No GSC, not my foot. It happens on both up and downshifts.
Old 08-27-2018, 09:09 PM   #12
CSaddict   CSaddict is offline
CSaddict's Avatar
Have them send an entire engine assembly and swap it out. Its brand new.
2016 CSC RX3 Ginger Edition
Check out my blog here:
https://www.facebook.com/My-CSC-Zong...0302595973417/
Old 08-27-2018, 09:28 PM   #13
GSC   GSC is offline
yes; also on up shifts if i didn't release my boot pressure from under the shifter. shifter needs to settle to be ready for next lift, you know.
in my experience.
Old 08-28-2018, 08:44 PM   #14
GSC isn't the only one. I prefer wheeler boots with traction soles since I'm not sliding all over. I have a longer shifter from my stack of old parts that fits and works perfect with the wheeler boots, a size to big for winter warmth layers, too sloppy with safety toe work boots in the summer. Fortunately, the stock shifter works perfect with the work boots, but the wheeler boots barely fit, with shift problems.
Old 12-20-2018, 03:09 AM   #15
NzBrakelathes's Avatar
I had a simular issue on my Zong 200 and it was the fork part actually floating out to far from the star wheel bit.
It would miss grabbing the pins on down shift - I reset the end float and slightly bent the fork so it wouldn't miss the pins it grabs on and all is 99% fine as only now n then do I get a slight miss grab/no grab but a wee flick or tap on the lever settles it back correctly
