08-08-2018, 02:19 AM | #1 |
Fuxin 110cc Pocket Bike
I am working on a FUXIN 110cc pocket ATV with a LONCIN motor and a SNYA two piece CDI.
There is no spark! The CDI main module has 8 wires coming out to the connector. The ATV picks up 6 of these. The second module has a 5 wire connector plugged directly into it. There are also 2 black leads (unconnected) and a two wire connector (horn maybe). Is there some guidance you can give so I may use a 5 wire CDI? Below I will try to show the wires and connectors: SNYA (main module) Gry Pk Yl _ _ _ R Blu Yl _ _ _ Bk Or _ _ ATV mating connector Bk/Wh Blu/R O O R/Yl O G R Bk O O O L’ LiHua (slave module?) G `Bk/Wh R I I I Blu/Wh Bk/Yl I I R = is usually + on this ATV Bk = is usually switched (control) G = is - or Ground (except sometimes) Here’s me hoping you can suggest a simple fix. The owner’s young sons don’t need the horn. Thanks for your consideration and help; James E. Kuss |
08-08-2018, 11:28 AM | #2 |
Please show us pictures of the parts you're referring to. That will be much easier to follow.
110cc loncin engine, cdi no-op, no schematic, snya cdi |
