Mikuni vm26 help
Hi all,
I was removing the needle jet and I pushed alittle to hard and the insides went flying. I think I found it all but wanted to check with you guys before I ajustband reassemble the carb. |
#2 | |
Make sure you seat the needle first then the retaining ring which looks like a bow. I made that mistake and had to disassemble mine again...
2017 Hawk 250 1998 Harley Dyna |
While we are talking about carbs... I have a mike I on my hawk... what’s the deal w the keihin pwk30 is it better can I get more power?? I’m in the process of porting a head and would change out carbs if I can get some more out of the bike when I change heads.. anyway thanks for the help!!
#5 | |
JerryHawk250 has a thread on this carb if you want more information. http://www.chinariders.net/showthread.php?t=21329
#6 | |
#7 | |
thank you
well i am going to get the better free flowing exhaust or may mod the stock one , cat too ,but not porting the head. just valve adjusted ,so should be fine with the v26 mikuni yes
Yeah, you found it all....ARH
