06-09-2018, 04:27 PM | #1 |
Vader build questions
So I bought a Vader. I like a challenge, the underdog. But I have a lot of questions lol. I'm looking at the grom ohlins fork internals. Does anyone know how close the Vader forks are to the grom forks? What about brake pads? Can I run grom EBC pads?
I haven't smiled from a motorcycle so much since my Daytona 675 race bike. Here is the Vader as it sits waiting for rearsets and a new brake disc. |
06-09-2018, 06:31 PM | #2 |
Nice. haven't seen a white one. Where did you get it?
06-12-2018, 08:27 PM | #3 |
Holy smokes, go camping for one weekend and all of a sudden everything blows up lol. I bought them from Venom Motorsports.
06-10-2018, 03:06 PM | #4 | |
Most of the differences between parts seem to be some of the cosmetics (panels, some lights, things like that) and the fuel delivery of the engine (fuel injection vs carburetor). Other than that, you should be good to go. EDIT: And mounting an aftermarket exhaust can cause issues, since on some of these bikes there is a mount missing on the swingarm for a low mount exhaust. Looking at yours, you might be ok in this department, but keep it in mind should you ever want to move the exhaust next to the swingarm. Last edited by siikmonkee; 06-10-2018 at 03:10 PM. Reason: Added information |
06-10-2018, 10:31 PM | #5 |
[QUOTE=siikmonkee;282899]Hey Logan - the brake pads should be the same, though I replaced the whole caliper instead of using the stock one on these clones. I also purchased aftermarket SS lines, and didn't have an issue with the installation. As far as the forks, I assume you should be ok with the replacement as long as you purchase the parts for a first gen Grom (2014-2016). I've had a lot of success with replacement parts from Partzilla using this model year.
Siikmonkee what caliper did you go with? |
06-12-2018, 08:33 PM | #6 | |
06-11-2018, 01:57 AM | #7 |
I had to replace the rear caliper when I got the bike, since there was a hole in the other one. Here, let me post the assembly here:
https://www.partzilla.com/catalog/ho...-brake-caliper It was a direct fit, didn't have to modify anything. I have very little doubt that the pads would work for the stock caliper as well, though I didn't personally try fitting the old pads. |
06-11-2018, 03:44 AM | #8 | |
CALIPER SUB-ASSY., RR. (NISSIN) and the PAD SET, RR. |
06-11-2018, 01:14 PM | #9 | |
Just ordered the front and rear rotors as well as a test to see if they are direct replacements. I'll post something (probably a new thread, I've been meaning to make a 'beginners guide of all things anklebiter') once I've received them and had a chance to do the install. |
06-20-2018, 03:29 PM | #11 |
What exhaust is that? I like how low it sits... may need to swap my exhaust over to that and sell my current one.
06-13-2018, 09:24 AM | #12 |
What rear sprocket is everyone using? I'd like to drop to a 32t but have had a hard time finding one. I just found a JTR 802.32 in a 428. Or can anyone tell me if a front 420 sprocket can be found in a 17t? That would really make me happy lol.
Edit: NM, I find a front sprocket easily enough. Still don't know about the rear sprocket sizing though. |
06-13-2018, 03:51 PM | #13 | |
06-15-2018, 12:24 PM | #14 | |
Has anyone solved the motor mounts coming lose yet? I added loctite and a lock washer but they still come lose on the regular. Here's an updated pic from last night from me fucking around. |
06-15-2018, 01:35 PM | #15 | |
For one, it's not stripping the threads or breaking the bolt anymore, lol. But it also seems to stay pretty tight. |
