RX3 running issues
I have a 2015 RX3 that recently developed issues. I rode it around 20 miles
with everything feeling normal then it started feeling roughness and flat in the rpm range of 4500 to 5500. when pushed through the flat spot it then picks up to normal revs. I've adjusted valves, replaced spark plug, air filter and fuel filter. Below 4500 rpm it feels good but flatness creeps in just beyond. Any thoughts from the RX3 group? |
#2 | |
I ask because I seldom, if ever run at 4500 RPM. The bike likes to sit at 6000 - 8000 RPM for best performance. If I am approaching 5000 RPM, I downshift a gear to get back to 6000 RPM or above. Every once in awhile, I may lug it that low but normally 5000 RPM is my floor. Some possibilities that I can think of off the top of my head, and not necessarily in the most likely order: 1. Fuel pump issue. 2. Loose spark plug wire connection, sensitive to engine vibes. 3. Intermittent electrical contact issue in the ignition system somewhere, again sensitive to engine vibration. 4. Vacuum leak somewhere, allowing unmetered fresh air into the fuel induction system. Try spraying starting fluid (ether) around the intake while revving it in the problem RPM range. Last edited by Working_ZS; 05-26-2018 at 08:34 PM. Reason: Add possibilities |
Little engines - mine too
My bike barely runs below 5500. My ride to work is relatively downhill but even so if I am rumbling along in 6th gear at around 60km/h and about 4000 revs I have to chage down at least two gears before I can open the throttle and get a response. If I do try to make the bike pull below 5000 it chugs and splutters pityfully. Change down to fourth, roll on the throttle and it's all go.
Once the engine is at operating temperature rev it, that's why it has a rev counter and short gearing. It is also much smoother over 6000. At 8000 I can almost see in the mirrors! I'd be suprised if any 250 single made pulls strongly at such low revs. If you don't like revs make sure you keep away from the smaller Japanese multi cylinder bikes. My CB400SF didn't go at all until about 8000 and pulled happily right up to 14000, all day! The guys at CSC did over 5000 miles with the original bikes and wrote about it at length - 5000 at 8000 the had no hassles at all. I think the 250 motors will outlive us all. |
#4 | |
Put new gasoline in the tank? Valve adjustment recently? I ask that because there have been more than a couple instances where the owner adjusted valves and didn't secure one lock nut, allowing the adjustment to change & mess things up.
Horse holder at Madame Orr's House. |
Definite drop in power that came on suddenly in this rpm range.
Revs strong when not under load but loses power when on road. I understand comments about low rpm however this is a new symptom. Additionally I have a 2016 RX3 to compare to and it's not anywhere near this feeling. I can start swapping components from one to the other as soon as I get some idea of what to change out. Comments about valves are considered but this symptom came on suddenly with nothing done and the bike was running good. after adjusting valves the bike runs better from idle to 4500 however that is where it loses power. after pushing through 5500 it takes off. Around town riding on either bike for me is always between 4500 and 6000 rpm. I run fuel from airport,93 octane super unleaded with Lucas treatment. |
Imagining that your valves are set to spec and that your plug, etc...are all known good, I'd suggest cleaning and tightening your battery terminals. These bikes s can do funky things if a terminal worked loose.
#7 | |
Both cases were issues with MAP sensor, 1 had a bad plug and corrosion at the connection the other a bad sensor. Check on the Diag PC and check air temp and air pressure etc. Or just do a qiuck swap between bikes as these are both in all years the same. Small hex bolt and pull the little black sensor out etc |
Update on issues with this motorcycle.
I've swapped ecu from one bike to another which made the 2015 run correctly. However 10 miles into ride it seemed to be starved for fuel. After that I disconnected the o2 sensor to run open loop and everything works great again. Then I installed the suspect ecu in the 2016 RX3 and had it running poorly. Once again I disconnected o2 sensor and it runs good also. Has anyone tried using o2 sensor available from auto supply? CSC is very proud of their sensor. any feed back will be appreciated. |
Any chance you've got an air leak in the intake train at some point?
Perhaps when you hit that 4,500 rpm range the leak worsens at that point, causes a lean condition which the F.I. computer then needs to adjust, resulting in the flat range? Cheers, Dan K.
Dan Kearney - Black Hawk, Colorado, USA ![]() Dan's Motorcycle Blog - "Lost? I'm not lost. I'm just exploring. . ." |
#10 | |
Swap the black MAP sensor on the manifold, they seem to be common to give issues. |
Problem found
I finally solved the issue with my RX3. After installing a new o2 sensor and
doing reboot on the ECU it all came back to life. When I asked about sensor from auto parts store I got no answer however I found that a Bosch sensor was a direct fit up and works perfectly. For people experiencing such issues I've found out that the Delphi FI goes open loop after about 80% throttle. It all makes sense now. |
Is there an available part #?? I'd like to keep one handy. My white RX is still exhibiting some oddities on occasion. Blue one is perfect, as always.
#13 | |
So far 3 from 4 bikes had this issue Also clean clean and micro clean throttle body. the stepper motor and the hole the plunger goes int to AND (most important)check that throttle is closed by looking thru it into the light - no light from top or bottom just a little maybe left and right side (kicks or bucks up the RPM from 1600 to 2100) It pretty much is an internal air leak instead of going thru idle it leaks past butterfly and the stepper get confused and bike revs up and or bugs down on very light throttle. |
#14 |
Is there a cross reference for the MAP sensor? Or do I have to pay big bucks from CSC?
Charles |
#15 |
Yes, Delphi part number 28086011.
