05-11-2018, 04:18 PM | #1 |
Help
I have an Apollo 250 and I press in on accident the rear shock an “air” came out now the shock is completely soft.
05-11-2018, 04:46 PM | #2 |
I'm not sure if your shocks are nitrogen filled or just air. Does your manual specify how many psi of air or nitrogen to use?
05-13-2018, 06:03 PM | #3 |
Just unbolt the shock and take it into a local motorcycle shop and ask them to recharge it to whatever they think. You'll never get close to the pressure it requires with a home compressor. I'd take nitrogen over compressed air, since it's less sensitive to temperature changes (or so they say).
05-14-2018, 07:02 PM | #4 |
nitrogen at 210 psi is what most motos run.
apollo 250, shocks |
