Accelerater pump Carburetor
Just got this today! It is a carburetor with an accelerator pump. I ordered it from aliexpress. I will be putting it on my Apollo 250 with the Zong engine. I will document it as I go and post pictures of the procedure. Sorry the picture is sideways.
PowerZone PZ30 IRBIS TTR250 Tuning Tuned Power Jet For Keihin 30mm Carburetor + Visiable Twister + Cable + Repair Kit+grips
https://www.aliexpress.com/item/KEIH...95aed01dbcdb6f This is the description from Aliexpress. All of this for about $43. And you get to pick what color hand grips you want.
2020 Kawasaki KLX300R, 2018 Yamaha TW200 If you want more of something, tax it less. If you want less of something, tax it more. Last edited by Its_not_a_honda; 05-13-2018 at 01:28 PM. Reason: added link |
Came straight from china.
No pictures.
Sorry! I had it on private. Can you see them now?
Ahhh!!! That's better. I though I was going crazy.
#7 | |
Looking for more umph when accelerating on the trails. I need the front wheel to a least make an effort to raise up when I need to go over a rock, tree, ditch etc. I thought it might be the clutch slipping but runs too well climbing. It pulled me and my wife through some stuff I had no business going through. Lol. So I am starting with the carb. Bike is stock except for 12 tooth front.
I think that should help some. Will wait for the results.
That bracket and spring are actually to allow you to run a cable choke for a handlebar choke lever if you so desired to set one up.
I had a carb much like that on an old Honda XL250S, and it was a pleasure to ride. The throttle response was noticeably crisper than the 30mm Mikuni carb I'm used to, even when properly tuned. That bike started with one lazy kick.
So here it is installed. No big deal on getting put on. It comes with a new throttle cable and twist grip. You can see the cable is white. The only thing to watch out for is the gasket and insulator/spacer that goes between the carb and intake. It can be put on backwards. One way it fits perfect. The other way it blocks part of the intake. I changed out my gas tank to a plastic one while I had it apart. It actually took me longer to get the tank on than the carb and it was made for the bike. lol
I really liked the bike before. Had plenty of power. Power just didn't hit a low rpms like I needed. Now it is like you say "crisper". When I grab a hand full of throttle I had better hang on. It is like having a hot rodded version of the Apollo. It starts quicker and no warm up needed.
Its_not_a_honda:
Are you located in the US? I checked the Orion site, and everything is listed in Euro. If in the US, how long did it take to get the gas tank? Douglass |
#14 | |
![]() Yeah the Orion site is in euros. I used paypal at check out and it converts to dollars. You can add all your stuff and google to get the dollar total if you want. I can't remember the time it took to get the parts. I think it was more than a week but not 2. I considered it fast compared to some of the china sites. lol Don't forget to get the gas cap!!!!
#15 | |
