There are bearings in there.... they most likely are sealed bearings. They are cheap to replace. It's possible the chain might be super tight.
Other then that I don't know... after playing the videos the whales off the coast are replying.. maybe they know something. |
I drilled, tapped and installed a grease zerk on my coolster 150.
Did you take the inside seals off of the bearings for this mod or were they already unsealed?
Thinking maybe they just botched the bearing install at the factory and whacked the outside of the cage with a hammer. Once that happens the bearing is never going to be right and short lived. |
I've yet to see a China quad with swingarm bearings. My 200 used cheap bushings, so I replaced them with bushings that are designed for a PW80. They're much better quality, cheap and a perfect fit.
I'm talking about the axle bearings in the housing.
Thanks for clarifying; I'm up to speed now.
#10 | |
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 02-27-2018 at 09:21 AM. |
#11 | |
I installed two zerks in the axle housing of my quad. One is for greasing and the other is removed during the greasing procedure, to allow air to escape. It's a trick I learned from farmers who drag trailers through creeks; if the housing is completely full of grease, water cannot enter. Since water is the primary killer of bearings, grease is cheap insurance. BTW, that's the actual purpose behind the design of the Bearing Buddy for utility trailers. It's not to speed up the process of greasing axle bearings. After you pack the bearings by hand and then install the hub, the zerk on the Bearing Buddy allows you to fill the space between the bearings with grease, again to keep water out.
Cool.. good to hear it was an easy fix.
#15 |
Love to see the zirc mod
Perchance of a quick pic of where the zircs are?
Any drilling and installing tips for the zircs? You can never have too many! Different track; about oil for my manual shift 250cc Rhino, shall I change to an engine oil for diesel vehicles? weight/brand? Thanks again... |
