stock exhaust port and ported exhaust. Head was decked .7mm
awesome! any idea what your compression ratio will be now?
I went from a 98 main jet to a 100 main. I"m gonna try a 105 next
Ya beat me to it! Pretty decent work so far. I might have left the exhaust port a little smaller at the exit to account for the copper gasket flattening out a bit, but it should still be pretty close.
If you deck .7mm, (.0276") that should put the compression right around 9.7:1 (give or take a tenth of a point. You could still remove some material from the port roof leading up to the valve guide, and around the sides of the guide as well to open that point up a bit more. Have any pictures of the runner bowls from the combustion chamber side after the port work. I have been contemplating how to attack them with mine.
You must be at elevation if you were running a 100 main jet after the port work, especially with that exhaust.
I am waiting for my new carbide burrs and some sanding rolls to get here so I can attack my head. My plans are a bit more aggresive for the ports at the valve guides and bowls. There is a lot of material that can be removed there. I also plan on decking .035 and smoothing the ridges down around the valve seats to unshroud them a little bit. (hoping to end up around 9.6-9.8ish) and polish the heck out of the chamber and exhaust port. I have another week until I even get home to start my head. Stupid adult responsibility called work...
Yeah i'm at 6500 feet
Looks good. Nothing too aggressive I see, just nice and blended/evened out.
Nice job Silva
Did you get a chance to check if it may a difference in your top end speed?
