08 roketa buggy cdi issues
I have a roketa buggy that has the 260 CC engine and I lost sparking it. I replaced the coil, plug, stater, voltage regulator,and cdi box. Everywhere I've looked it says an 8 pin cdi box but not what rpm it is. The first cdi box I used would get the engine to POp but not start, so I found a cdi box that had a 7500 rpm spec and lo and behold the bigger started right up. Finally I thought, well it ran for a couple of minutes and when I went to take it for a spin I backed up ten feet and it died.. blew cdi box. Any insight would be very helpful thanks.
Is it an AC or DC CDI?
Those Yamaha clone/ Linhai or whatever is 100% dc...
Possible short in wiring. Just start tracing all wires in and out of the cdi box until you find a burnt one touching something it shouldn't. Sometimes it actually helps to get your head in there and sniff around to find the burnt wiring.
So I guess my question then would be, which is the right cdi box for this engine.. I've tried three different 8 pin types with no luck, and I knw for sure its the cdi box.
#6 | |
What's the peak voltage of pickup? Low reading indicates the gap btw flywheel isn't right... http://chinariders.net/showpost.php?...1&postcount=17
