Old 09-03-2017, 06:33 AM   #1
Good LED Turn Signals.
After linking these in the Facebook group, I figured I would share these for all. The price in this link is for the full set of 4, front and rear. They do tend to go out of stock, but if you miss out they will appear back in stock within a couple of weeks.
https://www.amazon.com/Motorcycle-In...r%2Btrade&th=1
They are a bit more expensive than your typical LED signals you can find on ebay and Amazon, BUT, they are worth the extra money. These things are bright! Not just at night like in the video here, but they are fully visible in the daytime sun - something that cheaper LED lights often struggle with. Skip ahead to about 52 seconds if you do not want to view the rest of the videoVideo:
They are built to a very decent standard - I have had zero problems with moisture and condensation. They have some flex and the plastics seem like a decent quality ABS on the body, while the lenses seem like a thicker and more durable plastic as well. The lenses have yet to yellow from sun exposure, which my Hawk has had a lot of this year. I have spent way more than this on signals of similar quality.
Another bonus is that these use the standard Honda wiring harness connectors and color coding - exactly the same as the Hawk, and they come with more than enough wire to make the connections and route them as you need.
These are damn near OEM quality lights. From my own advice, spend the extra money. I have yet to find a single downside to these lights.
If I buy another bike, I am pretty darn sure these will go on that bike too.
Old 09-03-2017, 08:58 AM   #2
goat67   goat67 is offline
goat67's Avatar
Those look real similar to the ones on my Brozz.
2016 Brozz
Old 09-04-2017, 04:03 AM   #3
It wouldn't surprise me. The design itself is pretty generic. The material quality of these is why I recommend them. They are worlds better than most of the cheap LED signals I have found and tried before, and way better than the stock hawk signals, which on mine would fog up at the slightest hint of water.
Old 10-22-2017, 01:11 AM   #4
Musictrek   Musictrek is offline
Musictrek's Avatar
they are very nice! I ordered them!
Old 10-24-2017, 07:23 PM   #5
Glad you like them. Their price seems to jump up and down a bit, but they are worth the money.
Old 10-25-2017, 08:51 PM   #6
Musictrek's Avatar
I put two on the front and they would light just fine as long as I left the old bulbs on the rear. When I installed a new LED on the rear for the left. The left side front and back no longer worked. I know these led cant be pulling more juice from the battery. it must be a resistance load kind of thing. Anyone have this issue?
Old 10-26-2017, 12:47 AM   #7
Problem solved! I put a 6ohm resistor on the turn signal circuit. Now, both front and rear led lights flash like normal. The standard turn signal bulb s about 3-4ohms of Resistance. Bought resistors at walmart.
Just out of curiosity, ehat year is your Hawk? I am under the suspicion that the 2017s got an electronic relay from the factory. My flash rate didnt change after installing all 4 of mine.
Old 10-26-2017, 01:18 AM   #8
Musictrek's Avatar
mine is I think a 2013. I thought I had it figured out with installing a 6ohm resister parallel on the circuit for a left front and back led working signal. It worked then it didn't. I'm going to check my wiring. I did have it working under a test. I will be using two 6ohm resistors if this works out right.
I got it working great! After i soldered the wires up, both front and rear led lights worked like normal. They are nice and bright! I also moved all the wires from the wheel area to the cleaner and dryer location under the seat.
Old 10-26-2017, 03:30 AM   #9
Musictrek's Avatar
LED's! Six dollar hand grps from China.
Old 10-26-2017, 05:11 AM   #10
humanbeing's Avatar
...under the suspicion that the 2017s got an electronic relay...
Chinese parts house sold those universal @ 25 ¢ (Fleabay often @99¢ shipped from China) while the traditional 1 costs more
Old 11-16-2017, 09:07 PM   #11
my 2016 didnt change either
2016 hawk
kaw h1 400 tripple
13' long chopper in progress
2009 johnny pag bar hog
Old 10-25-2017, 11:19 AM   #12
CaptCraig   CaptCraig is offline
CaptCraig's Avatar
I have been watching this group for about a month as I am trying to decide if I will buy a Hawk, Enforcer, or the Storm. I am also watching to see if they have any new releases for 2018, but I have not seen many released in our class. I already own a Harley, but I had a stroke last year. I am going to get something that weighs 1/2 of the VROD. Those LED lights look really great on the Hawk! I appreciate all of the people on this site that give their opinions and take the time to create tutorials. It makes my decision on saving some money and weight with a Chinese motorcycle much easier. It is the simple things like MegaDan's videos that make the adjustment much smoother. Thank you!
Old 10-25-2017, 07:41 PM   #13
We are all happy to help here. The advice and knowledge from the members here definitely makes life easier when it comes to owning and maintaining these.
Sorry to hear about your stroke, and I commend you for wanting to keep on riding. If you have the funds, then of all of these bikes, I would say the tt250 is the way to go. The hawk is awesome, but the tt250 has a few upgrades over the hawk - coubterbalanced engine and suspension - that make it just a bit better, and having a warranty and dealer support is another positive. If you are on a tight budget though, there isnt much wrong with the hawk, but it does require a bit more effort by the owner to make a decent bike good.
Old 10-25-2017, 08:53 PM   #14
CaptCraig's Avatar
Thank you for the response! That TT250 is very nice. I actually really like the copper one. These will be out by December from what I can see. It is very similar to the Hawk. I'm sure there will be plenty of gadgets to improve upon, like the LED turn signals you are speaking of.
Old 10-25-2017, 09:17 PM   #15
The TT250 comes from the factory with LED signals.
