08-25-2017, 03:42 PM | #1 |
smog blockoff plate for cg250 emissions plug
Where can I get a plate to cover the hole where the emissions control system comes off the cylinder head? Apparently it's a thing u can get for bikes but idk where to get one for a cg250 engine.
08-25-2017, 04:21 PM | #2 |
I don't think you will find one. Most on here just fabricate one out of steel or aluminum.
09-26-2019, 04:22 PM | #5 |
keep it all china syndrome!!!!! my mrs commandeered the steel off of our crate to build a project!!!
08-25-2017, 08:27 PM | #6 |
How far apart are the bolts on these? Would this work? http://www.ebay.com/itm/311298248082
It looks similar. I have a piece of hose with a bolt in one end that's hose clamped on to it but it looks like shit. I don't wanna jury rig it. |
08-25-2017, 09:09 PM | #7 |
Evap block off plate, from Cleveland Cycle werks.
$14.95 but not currently available. |
08-25-2017, 09:10 PM | #8 |
Block off plate.
That's alot of money for something you can make for free,,,,just trace the plate you took off including the bolt holes,, transfer that to a piece of metal. An cut it out .
2015 zongshen rx3,,(Sold),,,2016 bashan storm,,2005 Harley ultra classic. |
08-25-2017, 09:28 PM | #9 |
Well I don't really have metal I can use lying around.
08-25-2017, 09:35 PM | #10 |
Block off plate
You only need a very small piece ,,guarantee if you trace it on to paper an show it to a garage or welding or machine shop ,,, they will probably give you a small scrap piece,,
08-25-2017, 09:45 PM | #11 |
Here is a link to what I used
https://smile.amazon.com/Dorman-Help-41050-Vacuum-Asst/dp/B000COB5TE/ref=pd_sbs_263_9?_encoding=UTF8&psc=1&refRID=WCBRB 3KNV68Q2SY08PVS I also took a tie wrap and used it to tighten it down a clamp would also work.
2016 Brozz Last edited by goat67; 08-26-2017 at 04:40 PM. |
09-26-2019, 04:03 PM | #12 |
I know this is an old thread but I was searching for a plate too. I would suggest that if you use a vacuum cap you also shove some folded up/rolled up aluminum foil down into the "J-shaped" pipe before putting the cap on it. I would imagine hot exhaust will eventually melt or ruin the rubber...
09-26-2019, 05:22 PM | #13 |
BaShan BSR 250 DB-41H 2018 Red BS250GY-18D JFG Racing Exhaust . Adjustable Shock 320mm . Brozz Digital Gauge . Renthal Fat Bar . 428 17x46 Sprocket . Fender Eliminator . Wheel Truing . Fuel Tank Repair . Keihin PZ30 Main-115 Pilot-38 Needle-1Washer Fuel Mixture-1/2 BSR Chronicles - "Project leads to more projects!" Yamaha WR250R Suzuki GSX-R 600 |
09-26-2019, 11:01 PM | #14 | |
I have asked/shown a hardware kit of common bits n bobs but lack of interest etc. Everytime I post stuff I risk my life huh! and to post stuff we had to wait 2 months to get permission with my wife's ID and they don't like me sending stuff. NOTHING is like you think etc |
09-26-2019, 07:45 PM | #15 |
Just curious what the advantage is to removing the whole assembly and blocking it off? Does it hurt anything to keep it connected?
