Lifan 200cc issue
So I recently got a lifan 200cc motor. Ran for about 2 miles and stopped. Got it home, opened valve cover, found the exhaust side pushrod sitting next to the rocker arm wedged in. I pulled the rod out and found about a 1/32"-1/16" bend in it. Replaced both rods and set correct clearance to about 0.05mm. But now it won't fire up, is there anything I can do? Something I did wrong or something else possibly damaged?
I doubt if the push rod popping out of the socket would damage anything, but the big question is why did it pop out in the first place? Any chance you over-revved the engine to the point of valve float and bent a valve? I'd do a compression test.
Oh forgot to mention that. When I reinstalled the pushrods I found that the clearance for the bent side was way out of spec. It had a large gap. So Im thinking it was just too loose and when I actually started riding it it popped out. But I'm gonna do a compression test next. I do feel a considerable amount of air coming out when I remove the spark plug. But I will check the actual psi levels.
There's 2 type:
![]() Check it 1st b4 order anything ![]() 大东 http://www.cqdadongqimen.com/ a big player in OEM 正洲 (100% owned by Taiwanese, some of their product found in chinese made Honda/ Suzuki ) https://item.taobao.com/item.htm?id=548474724568 also OKish === ![]()
#5 | |
What bike did you install that Lifan 200 in?
Inquiring minds want to know!
Doubling the displacement makes me giggle.
I would be giggling with you, if the flipping motor hadnt killed itself.
Any word on the compression test?
So I got it running pretty well for like a week. Now it wants to lurch and studder and bog down. I've taken the carb apart and cleaned it. I've replaced the fuel. Tried various setting on the carb. The spark plug isnt white or black. It's a nice chocolate color. So I don't know. Anyone have any suggestions?
#13 | |
#14 |
There is a running Honda SL 125 for sale on my local Craigslist for cheap. I'm tempted to buy it and install the 200cc Lifan. I rode an xl 125 for years in my younger days.
