Old 06-07-2017, 03:27 AM   #1
Entropy   Entropy is offline
Blown Hawk Engine
So I think my buddy blew the engine while riding at full throttle on the freeway.
Is there a kit to rebuild the top end, or what parts to buy individually? The cheaper the better for him.
Old 06-07-2017, 03:42 AM   #2
pete   pete is offline
pete's Avatar
Blowen ?....
is the con rod hanging out a hole in the crank case ?
pull it down and have a lokk before he's spends any money...
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 06-07-2017, 08:48 AM   #3
Ariel Red Hunter's Avatar
Originally Posted by pete View Post
Blowen ?....
We need to know more. What is your definition of "motor blown up"? In other words ---- Pete is one hundred percent right!...ARH
Old 06-07-2017, 01:55 PM   #4
Let's also clear up some confusion right away.
Top End rebuild kit. On most engines, the "Top End" means - valvetrain and cylinder head.
Do you mean that, or do you mean Jug (cylinder) and Piston?
Old 06-07-2017, 08:32 PM   #5
Good questions guys. He hasn't pulled the engine apart yet and gave me very little information other than it stoped running and wouldn't start again and was making weird noises. I'll report back once he's pulled the engine apart.
Old 06-07-2017, 08:58 PM   #6
Good idea. If he ran it wide open with the original jets in the carburetor very far on the freeway, it could have broken a piston or dropped a valve, since you say it was making weird noises...ARH
Old 06-07-2017, 11:14 PM   #7
dpl096   dpl096 is offline
dpl096's Avatar
Please keep us up to date and if you can please ask your friend for some pics of any internal parts that failed and or are damaged.....
― Thomas Jefferson
Old 06-08-2017, 12:46 AM   #8
JeremyC   JeremyC is offline
I was thinking burnt valve from not adjusting them or a melted piston from a lean condition at full throttle.
Old 06-08-2017, 07:23 AM   #9
Mudflap   Mudflap is offline
Could be something like a push rod out of it's socket.
Old 06-08-2017, 10:35 AM   #10
......while riding at full throttle on the freeway........
Two important questions: Was it broke in yet? How many miles?
Old 06-09-2017, 12:18 AM   #11
Yes, we broke them in correctly after first changing the oil. Them another oil change...
Bike has around 1000 miles.
Old 06-08-2017, 07:48 PM   #12
wheelbender6's Avatar
In NASCAR, we say "Blowed a motor". That broad term that can mean anything from simply a broken ring to a hole in the block.
Old 06-12-2017, 01:07 AM   #13
BARLOW   BARLOW is offline
BARLOW's Avatar
i am going to guess burnt/broken valve or hole in the piston, if it still has factory jets
Old 06-14-2017, 05:54 AM   #14
Ok, and that is based on the assumption that this bike was ran at sea level or the 5000' feet that it was actually running at?
Old 06-14-2017, 07:27 AM   #15
No, that lean problem is less pronounced at 5000 feet. I must have missed on of your posts, as this is the first I've heard of 5000 feet...ARH
