hole in flexible intake...
I should have taken the picture before the patch but...I was getting some popping / sputtering at idle that I couldn't shake. I discovered a hole in my flexible intake runner. I have temporally "patched" this with rtv and I'm waiting on it to dry.
Brozz owners check yours where I have mine patched. Heck, put a picture of yours here so I can see just how bad mine really was. ***Wondering if the TT250 intake is the same??***
Brian Previously owned / operated MOTO Xtreme selling American Lifan / Check out my friends at www.armattanquads.com "Imagination is more important that knowledge" Albert Einstein |
#2 | |
Yep. It runs much better now. Not sure how long that hole had been there but I know it had gotten progressively worse the last few days. Fairly sure that rtv will work for a while but Id still like to pick up a replacement if anyone knows where I could get the proper one.
#4 | |
It is, your right. But if you only know how much Ive had to bug them to warranty my rusted tank (still in transit from china), broken speedo cluster (was covered in brake fluid during shipping and its cracked all to pieces *This has since arrived*) , you would understand why I would just rather order it lol
#8 | |
![]() Rides a 2016 Bashan 18C with Blue PlastiDip, piped and jetted, USB charger, real-time digital volt meter, faux carbon fiber handguards, 5 COB led headlight upgrade, auxiliary led light bars, and an MSR shift lever with new grips, T6 aluminum handlebars anodized in blue, polished handlebar brace, decals, HD Unibear chain and spoke covers waiting on the always-full mod shelf...... |
On a side note, have any of you Brozz/Shark/Enforcer owners pulled the EPA smog air injection nonsense off your motor yet? If so, please post pics and the proper procedure as I'm truly considering this modification. With the aftermarket exhaust, this is creating a small backfire upon deceleration, in addition to my sneaking suspicion that my stock pilot jet is too small.
Thanks Big! Mine had a perfect square hole. So perfect for a few minutes I was convinced it was supposed to be there lol. But reality set in and I plugged that bugger. Put over 100 miles on mine today (almost hitting 1K) and boy she ran great! Gonna order another intake, maybe a mukini carb, and just enjoy the heck out of this Brozz
Thanks Jeff!
This is extremely common and will happen to most, if not all of them in time. It will on;y get worse until you have the entire rubber area coated with RTV.3
I've had three of them and replaced them with this. Works great and helps support the carb better if you run a pod filter too. Unfortunately "currently unavailable"...but that changes. I have not had any issues with them. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
#14 | |
#15 | |
