05-25-2017, 08:20 PM | #1 |
shark 250 remove baffle and cat
How do I remove the baffle and cat from a shark 250? Or is there a way I can just lop off the muffler at the end and put a non restrictive one on? I'm going for better air flow.
05-25-2017, 09:17 PM | #2 |
Gotta cut the pipe at the bulge and pull the material out.
05-25-2017, 11:06 PM | #3 |
and the metal is a bugger to weld back up i chased holes for an hour! then gave up and said to hell wit it and bought aftermarket pipe.
05-26-2017, 05:34 PM | #4 |
exactly where do i cut it, and can i use some kind of exhaust wrap and hose clamps instead of welding it?
05-27-2017, 12:32 AM | #5 |
no must be welded back.
05-27-2017, 08:25 PM | #6 |
could i just cut the end of the muffler off and not weld it back on? or would it be way to loud/clearly illegal?
05-26-2017, 08:43 PM | #7 |
I had to have a professional welder use his heliarc and a new piece of rolled steel to weld mine up. It's a very low-carbon steel. It was only $20 for his services, and well worth it!
05-25-2017, 11:14 PM | #8 |
The aftermarket setups are cheaper than when I first started researching China bikes. I only paid $115 for mine, shipped to my door. It's SO much better than stock, and ALOT lighter, too!
Rides a 2016 Bashan 18C with Blue PlastiDip, piped and jetted, USB charger, real-time digital volt meter, faux carbon fiber handguards, 5 COB led headlight upgrade, auxiliary led light bars, and an MSR shift lever with new grips, T6 aluminum handlebars anodized in blue, polished handlebar brace, decals, HD Unibear chain and spoke covers waiting on the always-full mod shelf...... |
05-28-2017, 03:13 AM | #9 |
Just my personal opinion here, but consider the costs and make a decision as such. At this point I am assuming you don't have personal access to a welder, so there will be a labor charge involved just to have somebody weld things back together.
Hack stock exhaust, remove cat, purchase an X brand muffler. Just for a nice round number, lets say this ends up costing you about $100. It may cost a bit less, but the average price for a 38mm ebay muffler is around 50-60 bucks. and I am estimating a shop would charge you $40 to do said welding. Obviously, if you do have a welder, then this is by far the cheapest route to go. This also constitutes downtime of several hours. You are then left with a low carbon mild steel exhaust that will be prone to rust. Aftermarket Ebay exhaust. No, it's not super high quality, but it is still a low grade stainless steel, which if it does corrode can be cleaned up with steel wood and some WD40, then polished again. It's lighter, already comes with a good straight through style muffler, and requires maybe an hour of down time to install. Can be delivered to your door for $129 or less in as little as 3 or 4 days if you find a US based distributor. Not saying you can't or shouldn't modify the stock exhaust. If that is what you want to do, and you can do the welding work yourself, then go for it. It will definitely be budget friendly in that instance. The second you have to involve somebody else to do any sort of work, specifically welding, the cost effectiveness goes out the window.
05-28-2017, 07:21 AM | #10 |
You don't need to weld. Just cut the cat completely off and put a section of pipe with a muffler clamp on each end.
05-28-2017, 07:49 AM | #11 |
I'm fully equipped to do this job, resulting in FAR nicer welds on the factory exhaust. My time is FREE. And I still opted to buy the aftermarket system for two reasons: it's made of longer lasting (and better looking) materials. And reason number two is a biggie: It's WAY lighter. ALL of these bikes are underpowered imho, so your bike's power to weight ratio is ALWAYS the bottom line. Save your money, and buy the exhaust when you're able. It's worth the wait
