Engine bolt broken Vader 125
If you own a Vader 125 make sure you check your engine bolt. Took a ride today cut short because of rain. Went out and started it up for another ride and heard rattling. Looked and saw the engine bolt vibrated almost all the way out. Best bet would be to just change it out before this happens. I believe it's 4" or 4 1/2", I'm not really sure cause I couldn't get it back in all the way and it measures 4" as is. 10mm wrenches will do the trick for the bolt if your going to replace it. You'll also have to take the foot pegs off (12mm, 14mm and 17mm) sockets for the pegs. You'll also have to lower the chain in order to replace it. I haven't done it yet but I've taken everything apart already so I can put it back together when I get a new bolt. I'll probably get both a 4" and 4 1/2" bolt just to be safe. Hope this helps!
seems like a pretty common issue. I think i'll go ahead and nip this one and replace it. Thanks for the heads up!
2002 Harley Davidson XL883R 2012 Yamaha FZ6 2022 Hawk 250 2002 Yamaha R6 *sold* Vader 125cc *sold after owning for many years* 1997 Jeep Wrangler *sold due to frame rot* |
I measured the engine bolt when I took it out, 4''. Bought a 5/16'' 4-1/2'' inch steel replacement today. It should do the trick. I bought a lock nut and 4 steel washers as well. Not sure about the swing arm bolt. I suppose when I replace the engine bolt I could try the swing arm but I don't have a garage or bike lift. I've also had a problem with my chain coming loose. I've tightened it 2 times already and I don't ride it that much. I'm not sure what to do about it.
why did you take the pegs off for this? i did the bolts on mine and there was no need to remove the pegs you could of cut the 5" bolt also to make fit a little better and still use the washers like you did.
It was a pain to get to with the pegs on. I have limited tools and no lift or stand. I only removed them from the one side. Why would I buy a new bolt and cut it when I could buy one the right size? Sorry for being a noob.
#8 | |
Skin Mechanic also has a good write up on his engine bolt replacement. It should be the same for Vaders as I'm pretty sure they're all the same when it comes down to it. I will go ahead and order some replacement bolts too since this seems to be too common.
Not sure about the swing arm, but will look into it. It is surprising that your chain is loosening up frequently. The main nut on your rear wheel should prevent that from happening right? Between that and the chain adjustment nuts, I don't know what else can contribute to that. Quote:
#9 | |
Chain issue fixed, 94 jet
The bolt on the sprocket seems to have fixed the chain issue. It's still as tight as it was when I put the bolt in the sprocket. Also tried a 90 jet in the stock carb and it bogged down at top end of each gear. Went with a 94 and its running better. Could probably get away with a 97, but I don't feel like taking the carb off anymore..
Bored messing with jets
So I did try 98, 96, and 92 jets out of boredom. Had to go back to the 94. Running better altogether with it. It's weird how an 87 and 94 work but a 90, 92, 96 and 98 don't.
Always use Loctite on motorcycle fasteners; it helps a lot.
