Oil cooler install
My oil cooler finally came in today. It took me about an hour to install. After I installed the cooler I added oil with the provided syringe. I cranked it up to prime the oil lines and checked the oil level and added a little more oil. I took a ride down the road and came back and check the oil again. A check valve is not needed if you connect the line out from the engine to the bottom of the cooler. I let it set for an hour and the oil didn't drain back to the engine. I'll have to shorten the line with the filter when I get a chance.
Addition info: I used a piece of 1" angle iron using the two motor mount bolts at the bottom . After I mounted I realized I could flip the cooler mounting bracket and will set the cooler further back and the oil lines will be behind the angle iron. I'll take care of that and post pictures when I get to it.
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 06-02-2017 at 11:08 AM. Reason: added more information |
Looks good! Is that one from mj? I'll get one eventually.
On a side note, if you tweak that wire retainer for your front brake line, you can get it to go inside of both of those ridges on that rubber insulator. It takes some judicious bending and squeezing with pliers. My OCD made me do it! |
#3 | |
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 05-11-2017 at 07:50 AM. |
I agree...looks great. Well done indeed
************************************************** *** " Time you enjoy wasting, is not wasted." - John Lennon ![]() “I predict future happiness for Americans, if they can prevent the government from wasting the labors of the people under the pretense of taking care of them.” ― Thomas Jefferson "If you don't know where you're going any road will take you there" ....George Harrison song |
#5 | |
Yup, To the point it's cheaper 1 at a time with shipping than in bulk as China post small items are pretty cheap to ship. I got 6 of the valve cover coolers in with the stacked plate coolers and shipping alone was $129 usd. My wholesale price with shipping in bulk is more than you paid. Still waiting on seeing if they can come up with an UNCRIMPED end on one hose but haven't heard back. On your routing, Not sure it make a lot of difference on a bike but on cars, Trucks, Heavy equipment and hydraulic systems the hot (out) line always goes to the top as heat rises and if it went into the bottom the cooler/radiator efficiency is compromised. Just food for thought.......... |
#6 | |
Post some pictures of your install. If I remember right you had installed a check valve on yours. It will work that way just have to make sure that the cooler is filled completely with oil so that air will not get trapped in the cooler. But I know you knew that already.
#8 | |
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 05-11-2017 at 09:48 AM. |
#9 | |
Just send the units out with a check valve that way when installing the check valve the length could be adjusted then. ![]()
#10 | |
Do you have the link to the version of the oil cooler with the stacked plate cooler? Also, did any one else have a problem having the page from the link no translating? |
#11 | |
View the TaoBao site with Google Chrome to translate it.
#12 | |
Thanks. All i use on this PC is chrome and every time i translated it it would stay the same. |
#13 | |
How do you order from this site if you can't read chinese?? Asking for a friend... LOL |
#14 |
Open with Google Chrome. It will translate it for you.
#15 | |
TaoBao Payment
Did you pay direct to them with your credit card? I went through the whole set up process and they confirmed the order. There is a tab to click for payment but it is not a PayPal link but it looks similar to PayPal. When I click it, it immediately asks for my CC info when usually it would direct me to PayPal and then back to the merchant. I don't feel comfortable giving out my info to an offshore merchant. Seems fishy to me. Please advise. I also sent you a PM Last edited by BBOWL10; 11-25-2018 at 11:05 AM. Reason: Addition |
