Loncin RE250 6 speed
I found a good replacement engine for our China bikes. Loncin RE250 6 Speed Not bad for around $530. 6 speed and counter balance
Wonder if they will bolt right up without any modifications? That is a great price considering the extra gear and being counterbalanced.
2016 Bashan Brozz 250 |
#3 | |
Specifications
Engine type
Single cylinder, 4 stroke, oil-cooled Displacement 223.0cc Bore x stroke 65.5×66.2mm Compression ratio 9.2:1 Maximum power 17.7hp(13.2kw)/8500rpm Maximum torque 17.2N.m/6000rpm Starting method Electric Ignition system C.D.I Idle speed 1300 rpm Engine oil capacity 1.3 L Transmission Transmission system 6-speed Final transmission Chain
This is one of the Enduro bike's it come on.
It's OHC too!
I think this is the motor that Fastdoc once put in an XR200. Not sure if it was a six speed though.
Might be the next mod for the Bashan WILL 200... 6 speeds, OHC engine, and 223cc's sounds great to me
![]() I also found a few sweet oil coolers on that yoycart website... just don't know what one to pick... I can't read the "Description" page and all the translator websites claim it's already translated into English ![]() Here's one of them http://www.yoycart.com/Product/548221350096/ Can anyone make out what one comes with the nice "rock blocking plate"?!? Is it the ones labeled "Mesh" ?!? ![]() ![]()
#8 | |
https://world.taobao.com/item/254075...?fromSite=main
That is the only reason I have not bought one yet. I much rather have the stack plate cooler.
#11 | |
#12 | |
![]() ![]() ![]() I wonder what happens when a china bike hits 88 miles per hour... probably need a Flux Capacitor for it to go any faster
#13 | |
#14 | |
![]() Daaaaang! You're pushin 8 feet tall?!? I'm almost 5' 10" on my good days (those moments right after a Chiropractor appointment)... we must look like ants to you giants ![]() Just do a good tuck... we are all the same height when our face is buried in the headlight plastics ![]()
#15 | |
