11-23-2016, 10:40 PM | #1 |
oil check
i have never known for sure but do you check the oil level on the dip stick with the bike on the kick stand or level? screw in dip stick or just push in and pull out with out screwing in?
11-23-2016, 10:44 PM | #2 |
The bike should be level. I use the sight glass to be sure about the oil level.
11-24-2016, 12:49 AM | #3 |
Level & w/o screwing in (sight glass is safer...)
~29:50
11-24-2016, 09:55 AM | #5 |
Use the sight glass, and cut the dip stick off the cap and throw it in the garbage. After what happed to C1500's bike, that is the FIRST thing I will do to my bike once I get it.
11-24-2016, 11:09 AM | #6 |
The CG motor? Drain, plug, dump in a full quart. The counter balanced motor, a bit more....but check the site glass straight up before topping off. That easy.
11-24-2016, 11:39 AM | #7 |
Yep, the dipstick is not to be trusted.
11-24-2016, 07:14 PM | #8 |
11-24-2016, 07:38 PM | #9 |
Letsride..... I clipped mine off too after those pictures. Any future problem...solved
Those dipsticks always seem to cause trouble
11-25-2016, 11:35 AM | #10 |
If the dipstick is to break off and end up between the primary reduction gears, it'll make a mess. Moreover, the dipstick is terribly inaccurate; if you were to fill the engine properly using the sight glass and then check the oil with the dipstick, you'd see what I mean.
11-25-2016, 04:12 PM | #11 |
where on the sight glass should it be halfway or to the top?
11-25-2016, 04:16 PM | #12 |
My concern is that not all bikes have a sight glass. Funny thing is my old TMEC 200 not only does not have a sight glass, but it requires a liter of oil, not a quart!? I am fairly certain the current model years' TMEC 200's still require a liter.
11-25-2016, 07:34 PM | #13 |
Yes halfway to the top.
11-25-2016, 07:48 PM | #14 |
Anywhere between the upper and lower lines. If the bike is new, tend to go toward the upper line. Why? Others will chime in but I had heard that the bike will use oil during break-in as things seat and you don't want it to be low.
11-29-2016, 11:11 AM | #15 |
Typically, one litre of oil will take the level to the top line of the sight glass, which does not fully submerse the sight glass.
