Old 11-04-2016, 07:55 PM   #1
vomitis   vomitis is offline
Dong fang dual sport not starting
Ok here is my problem. I have a Dong Fang df250rte and the thing won't start.
I've checked the obvious stuff. Spark is good, valves adjusted, carb cleaned and bike is getting fuel. The air filter is clean also. I put my hand on the carb throats and it sucked my hand good so I assume I have good compression.
Also I tried starting fluid and it didn't even pop.
The kill switch checks good too.
I'm stumped, anyone got any ideas?
By the way it has the 229cc pushrods engine.
ThAnks!
Old 11-04-2016, 08:04 PM   #2
Is it 'trying' to start (i.e. starter whine)? Have you tried kick-starting it? Checked the battery? The CDI's are sometimes bad or go bad as I found on my TMEC enduro I had bought new a few months prior to it going bad.
Old 11-04-2016, 08:32 PM   #3
Nope, it just cranks. The battery is good and kick starting has the same result as the electric start.
So it could be the cdi box even with a good blue spark?
Trouble free since new in 2012 now this.
Old 11-05-2016, 07:34 AM   #4
Disclaimer--I am no mechanic nor claim to be, but have been able to troubleshoot and fix a few things here and there.
I had a 2009 TMEC 200 enduro I bought used--road it for a couple years, then replaced with a new TMEC 200 enduro. One day, the bike died and would not start. This was just as I arrived to work after 16 miles on my daily commute. A coworker took me home. Someone was posting the same thing here on chinariders with their bike--it was fixed with a new CDI as their old one had gone out.
My new bike had probably less than 1000 miles on it (my old one had about 10K at least that I knew of since the odometer/speedo was never working when I bought it). I still had the old bike and it was apart in a few pieces. I took out the old CDI, had my wife drive me down to my work, and realized I had forgotten the keys! I would not know if that was the fix since my wife needed the car later on, so I would not be able to retrieve my bike that day.
My coworker graciously took me to work in the morning. We work in the local state prison complex, and I had my bike parked outside the main gate so I could work on it and not have to get checked in (the evening before when I forgot the keys). I anxiously hopped out of the car (my coworker waited for me since our unit is a mile away from the main gate and they don't let employees walk around the complex anyway), put in the key, and the bike fired up like a champ! I called Excalibur who I had bought the bike from, and they sent out a new CDI under warranty. For good measure, I bought another one. I never did need either one.
To repeat--I am no mechanic nor am good at diagnosing, but did have this happen to me, so I always throw it out there. My bike was 'almost' starting; kind of like when a plug is fouled (I had that happen on my old bike, and I started carrying a new plug with me in my top case for quick roadside plug change). Since I happened to be following an active thread in which someone had a similar situation just a mere few days before me, and the helpful members here threw out all the suggestions, such as carb, plug, kill switch (still gets me on occasion ), etc. to no avail, and he narrowed it down to CDI, and that fixed it, that was where I started since I had my old bike and its CDI, and it fixed it for me. I know that CDI's are not expensive, so, after a plug change as 'Pete' suggested (very cheap and simple), if that does not do the trick, next, order a $10 (probably less) CDI off ebay and see if that solves it (unless you have someone you know with a Chinese bike with a similar CDI that you can borrow)
Old 11-04-2016, 08:37 PM   #5
Adjuster's Avatar
You cleaned the carb? I would start there and anything else you messed with prior to the new problem.
After cranking the bike over for several seconds remove the spark plug and see if its wet with fuel.
If you have spark and fuel you should get some sputtering no matter how messed up everything could be.
Old 11-04-2016, 08:48 PM   #6
Yep carb is clean and there is fuel on the plug. I even tried a different brand new carb and it did the same thing.
I'm with you on that last part it should start or fire.
Old 11-04-2016, 08:51 PM   #7
Could a bent pushrod cause it not to start?
The rockers looked like they were moving properly.
Even with that it should still fire or backfire I would think
Old 11-04-2016, 08:51 PM   #8
Adjuster's Avatar
Just for the heck of it try a new spark plug. Possibly internal broken plug losing its spark when its tightened down.
Old 11-04-2016, 08:55 PM   #9
Thanks for the advise guys, I'll stew on this and check back tomorrow.
Maybe it'll come to me in a dream lol
Old 11-04-2016, 10:23 PM   #10
Ariel Red Hunter's Avatar
I just couldn't resist - sorry. Somtimes you have to flong your Dong in order to get it ready for action.
Old 11-05-2016, 02:13 AM   #11
Did he try the plug on the frame test to verify spark?
Old 11-05-2016, 06:41 AM   #12
Panic-Pete   Panic-Pete is offline
Panic-Pete's Avatar
Is there a sidestand switch?
Disconnect it. If it starts up.. that it was.
How about the kill switch on the handlebar ? Sometimes it´s the simple things.
Je suis Paris, je suis Europe !
Liberte Egalite Fraternite !
Old 11-05-2016, 06:56 AM   #13
pete   pete is offline
pete's Avatar
both these stop the spark... and he says it has spark...
but a plug can seem ok out of the motor & have a weak or no spark under compression..
can't hurt to replace the plug....
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 11-05-2016, 10:53 AM   #14
Roflmao! That's the reason I don't tell the brand when someone asks
Old 11-05-2016, 07:26 AM   #15
pete's Avatar
have yer checked the piston...
could be why it WOODEN start.
useing them go against the GRAIN of
most companys but theres a small
SPLINTER group of companys that use them..
09 XT660R ...
06 TTR250 ...
81 Honda CT110...
