08-07-2016, 11:06 AM | #1 |
Check your right side cooling fan.
Came back from a 250 mile ride and went over the bike visually. Found the radiator hose rests on the right side radiator fan and has pushed it into the radiator and the fan doesn't move. I need to look further into it early this week week to find out if the fan is now damaged or the radiator itself. So check those fans and hoses.
2016 CSC RX3 Ginger Edition Check out my blog here: https://www.facebook.com/My-CSC-Zong...0302595973417/ |
08-08-2016, 09:06 AM | #2 | |
good to just always check everything. thanks for posting this |
08-14-2016, 12:43 AM | #4 |
Nailed it...
Good call CSaddict! I did about 4 hours today and it was hot. 102' in spots. The bike never pegged the gauge but I noticed when the fans were on, only the left one was on.
I got home and checked and sure as hell, the right fan was being halted by the hose. I'm not sure if this was something that may have misaligned from my last valve adjust or what. I know it was tight...everything is tight inside these bikes. I thought of using a zip tie or something to pull the hose back a little for a quick fix but ended up making a small bracket and moving the right side of the fan down a scosche to clear the hose and leaving it in its natural place instead. All good now.
"Light a fire for a man, and you heat him for a day. Light a man on fire, and you heat him for the rest of his life." 2007 Suzuki DRZ400S (SM convert) 2009 Q Link XP 200 1967 BSA B25 250cc Starfire 2022 Royal Enfield Interceptor 650 2023 Royal Enfield Scram 411 1948 Royal Enfield Model G 350 Last edited by 2LZ; 08-08-2017 at 03:58 PM. |
08-14-2016, 11:42 PM | #6 |
Panasonic, hadn't noticed that before.
08-15-2016, 03:06 PM | #7 | |
Perhaps these "open" fans have only been fitted to later bikes. Can't really see this style of fan as being an upgrade |
08-15-2016, 03:21 PM | #8 |
Or maybe it's a U.S. thing. Both of ours are from the early, first shipment here and we have the open fans.
08-15-2016, 03:38 PM | #9 | |
I wonder why the decided to change the fan design for the U.S RX3 |
08-15-2016, 05:13 PM | #10 |
I know. One would think that they'd have the fans completely shielded here so the high speed toddler that was following you down the road at 60 mph couldn't get their fingers caught in it. ;-)
11-16-2016, 09:53 AM | #11 |
Not cool at all Juan Carlos. When I found my right side hitting the hose, I figured it was from me moving it all around for the valve adjustment, but you only have 350 miles on yours. My left one seems fine.
