Old 07-17-2016, 09:44 AM   #1
Mrs. 2LZ TT250. Into the Fire....
....and out like the Phoenix.
Hi gang, Just wanted to give you all a heads up on the latest project. After our morning ride today, the TT250 will be going on the rack for the tear down. I have about half the parts here now and the rest should be arriving sometime next week (hopefully).
For those who wish to follow along, the project will consist of the following, but I'm sure will change as it goes along.
Motor, starting from intake: New K&N style breather, Mikuni carb with a mix of jetting, post-break-in valve adjustment, swap to iridium plug, new exhaust (wrapped), switch to synthetic oil. Re-torque every motor mount.
The rest: Go through the forks, new fluid. They've been working sub-par to date, are still slightly twisted in the trees (binding) and they seem over-filled on fluid (just guessing). Drop off rear end including swing arm and shock. Grease everything as it should be, including link and readjust the shock. I currently went overboard on softening it for Mrs. 2LZ. Replace the stock horrible chain with a new one. The stocker, regardless of lube, insists on kinking in spots. Unacceptable. Replace the stock 50 tooth rear sprocket with a 47 from JT Sprockets. I'll be gambling on a JTR269.47. Also, on top of the already added cockpit bling, I'll be mounting some 30mm Tusk risers, per Mrs. 2LZ request. If I forgot anything, I'll add it later. In addition, if the new gauge cluster from "mjstef" comes through, that will be part of the project while I have it down. Also, I have two new Kenda Tuff Tubes in stock....but I may not change out the original China Condoms until they blow. We'll see. So far, they're holding and I may just wait till I swap to the Shinko 705's...but surprisingly, we're really liking these stock tires so far for our riding habits.
Schmise: Safely remove and store everything smog related. Make a plate and block off the hole in the head for the pump. Finally, weigh everything between old and new to see overall fat savings. I'm hoping to gain a 3-4 HP (per butt dyno) and lose up to 10 or so pounds. Just guessing at this point.
Anyway, stay tuned if you wish.... Many pics to follow.
Old 07-17-2016, 12:23 PM   #2
pcspecialist   pcspecialist is offline
Are you sure you want Shinko 705's? I think they are the absolute worst tires on the planet.
Old 07-17-2016, 01:51 PM   #3
Good luck on your weight loss
This is going to be great.
Just wish had actual stock basis dyno course which would you rather do spend money on dyno test or on actual Mc parts, I think we know the answer.
Old 07-17-2016, 06:51 PM   #4
dpl096   dpl096 is offline
dpl096's Avatar
[QUOTE=BlackBike;225161]
DITTO !
― Thomas Jefferson
Old 07-17-2016, 08:34 PM   #5
Strange. They rate well and supposedly better than my Kenda's that I like on Q. We'll see....... The stockers sure seem to be surprisingly good for a stock tire regarding paved twisties and dry gravel roads.....
Old 07-17-2016, 09:15 PM   #6
Headway
I got up early this morning, posted the thread and then headed out to the garage to get everything ready. Cleared a shelf and a bunch of bins. ready to play!
Got back from our morning putt around 11:30. Got the TT on the rack around noon and went at it. Being a NASCAR fan, it was a tough job thanks to Loudon NH. Mrs. 2LZ would yell from the house, "Yellow! 18 out front!"...and I'd have to run in and see the restart. Needless to say, it was "Wrenchus Interuptus" quite a few times today....but I persevered. The bike had 13+ hours on the clock since I installed the tach unit so it's ready to go!
There were quite a few things I discovered today. First, I'll need to get a hunk of black plastic and fab an inner rear fender if I want one. The back of the air box plays that roll and it's now in the pile. No big deal.
Secondly, as expected there is very little grease on the swing arm pivot, axles or shock links. Also, I think with the scads of these CSC got in and needed to ship, it was pretty obvious that the valve cover had not been off. I think they give them the "does it rattle?" test and if so, send. Can't blame them really. The bike ran really well.
I took off all the smog, blocked the vac port on the intake manifold the old fashioned way (which I may replace) and fabbed the plate for the smog pump hole at the head so it's ready to go. Carb, exhaust, etc....all in a pile now. Need parts.
I was VERY impressed with the machining. I thought the rocker assembly was nicely done on my Lifan motor, this was impressive. Nicely done by Zong.
I got those ugly, scratched up bars shot today in the closest thing I could find to the dark, dark gray that's on the plastic's The pic doesn't show it but it's a very close match. Good enough.
Anyway, the bike's down, on TDC and ready for the valve set tomorrow after work when it's ice cold. I think that's about it for now.........
Old 07-17-2016, 09:17 PM   #7
Continued
More pics...
Old 07-18-2016, 11:43 AM   #8
SeerAtlas   SeerAtlas is offline
Thumbs Up
yeah butt, on loose grav,wet grass, or 1/4 " mud or better, that front is washout city!
immediately swapped mine for a tr8, diff between 'chit and chocolate
first thing you notice, stock tire is wayyyyy lighter, thinner walled, definitely 80/20 90/10 road biased tire. if that's what you ride, you'll b happy. if you want to follow your buddies/ kids "OUT THERE", swap it out and save yourself some headaches, (and various other contusion caused pains). Also, as my mechanic said when he saw the stock tube, "looks like a mountain bike's!"
The TR8 in front transformed my bike. now feels VERY solid and planted on road. It may make the bike a hair slower, but the feel of security and added confidence is worth it for me. no increased vibration, or noise to me.
Rear seems ok for now while I'm breaking in, but the difference in profile, aspect and traction between the stock rear and the Hawk's knobby is DRAMATIC.
Seer's First LAW-"FLY THE PLANE!", fail that, and nothing else matters. 12th Law- Consider what marvels you might do if only you had tomorrow to live over again. Third Law-When someone tells you some thing "Can't Be Done", what they're really saying is They can't do it!!14th Law-Just because something "IS", doesn't necessarily mean it SHOULD be.. Eighth Law-The only true personal security is anonymity.Ninth Law-Humans tend to learn very little when speaking.10th Law-Some lives ARE worth taking
Old 07-18-2016, 07:38 PM   #9
2LZ, now that your naked, so to speak, you can grease connectors and tape them up for waterproofing. (Not speaking to you , you taught the course).
I greased my swing arm bolt and rechecked the valves also today (2nd time easier now that I didn't have to us a Sawzall and a weld and grind routine like the first time). Set them both at .008mm
Also noticed a broken angle iron mount for the mid pipe to the muffler. Will have to weld err up. Found a few wires trying to comment suicide on the hot engine too. Can't take anything for granted with these scoots.
Thanks again
Old 07-18-2016, 07:46 PM   #10
2LZ... would you consider a light coat of clear satin or gloss now that the frame is so exposed for additional rust proofing. Oops, I forgot you are in california, no rust!
Old 07-17-2016, 08:07 PM   #11
hertz9753's Avatar
I think 2LZ was a Dokken fan back in the 1980s.
Old 07-17-2016, 08:32 PM   #12
Nah..... I was more Hendrix, Zeppelin, Cream, Airplane, Alice Cooper.....
Old 07-18-2016, 12:15 AM   #13
I here ya,(worn out cassettes of dokken,scorpions etc) back up a couple of generations for 2lz.
Old 07-18-2016, 12:28 AM   #14
So there were still some gap on the "air valves" as the owner's manual calls them?
Thanks for taking the time and posting all this stuff
Also, could you show a pic of how to grease the swing arm when you get around to it.(other than just greasing the bolt, is there actual bearings?)
Thanks
Old 07-18-2016, 10:04 AM   #15
Thanks
The swingarm is just bushed. There was some grease on them but I'll be coating the entire pivot bolt with a glaze of grease just for the corrosion aspect, along with regreasing the bushings. I've had swingarm bolts rust in place. Not cool.
I'll be posting what gaps I find in the "air valves" after tonight. They did tick so that's good.
