Old 07-15-2016, 11:16 AM   #1
mq1991   mq1991 is offline
Thumbs Down I sheared more sprocket bolts...
So I replaced the stock sprocket bolts with Honda ones, hoping I wouldnt have to worry about the little buggers anymore.
Now, instead of the stud shearing off into the hub, the nuts are popping the threads off just above the sprocket. I cant seem to find out how its doing this.
I installed the posts with locknuts, it doesnt seem like they loosened, just popped the threads right off of there.
Any suggestions for some other sprocket studs? Not sure what to try next...
Thanks guys.
Old 07-15-2016, 11:43 AM   #2
That's really strange. You running nitrous? ;-)
One would think that with the c-clip plus nuts, it would stay put.
What torque spec did you use?
Old 07-15-2016, 11:50 AM   #3
Azhule   Azhule is offline
That's my question too... How many ft lbs did you do?
Old 07-15-2016, 11:53 AM   #4
Nah I think its just the raw power of the hawks engine.
Its very odd, because the way it broke the sprocket is still driven. The threads still protrude into the sprocket.
I did 20ft-lbs. I checked them after 20 miles and 100 miles and they were still snug. Now about ~800 miles later that's how they sit. Only one locknut still on.
I ordered some of the "high tensile strength" ones for taobao, I guess we will see how those work. These stupid things are hard to find at a reasonable price.
Old 07-15-2016, 12:04 PM   #5
You're going to need to re-jet to take away some power.
I suspect that 20 ft/lbs is a little high. Assuming it's around 5/16" and about Grade 5, the spec would be closer to 13.
Old 07-15-2016, 12:07 PM   #6
Dang... I figured it was close to the fork clamp bolts.
Another thing I noticed when installing these studs is that they were smaller than the originals. You can see in the picture the larger hole where the original size wouldve fit. The sprocket has two sets of holes, so if I can find the correct size hopefully it'll stay together.
Old 07-15-2016, 12:06 PM   #7
Did you change the bushings as well? Perhaps Honda bushings would be a good plan.
Also, red Loctite might be better than high torque on the fasteners.
Old 07-15-2016, 12:09 PM   #8
No, the bushings still seemed to be in good shape. It was a very snug fit fitting the posts into them. (How do you get the bushings out?)
Ill do that next time, im planning on locknut with lock washer with red loctite. @ 13-15 ft lbs. lol
Old 07-16-2016, 10:32 AM   #9
There's a tool for that. It inserts into the bearing and then a stem is tightened which exerts pressure towards the inner wall of the bushing. Once that's tight, you turn an outer bolt that applies pressure to an outer collar that sits just outside of the bushing on the hub. As the bolt is turned, it forces the bushing out. You can find them on Taobao.
If the bushings aren't sloppy, I wouldn't bother at this time.
Old 07-15-2016, 12:09 PM   #10
Maybe go to the lower end of the "Sprocket Torque Specs", 18 - 28 Nm (13 - 20 ft lbs)
Might try going with 13 - 15 ft lbs of torque to hold those bad boys in place without breaking them
Old 07-15-2016, 12:17 PM   #11
This is all good to know since I ordered a new sprocket this morning! :-)
Old 07-15-2016, 01:00 PM   #12
Hope yours stays put!
I also dont ride my bike very nice. I wheelie it alot, jump it higher than its supposed to, hit the rev limiter every once in awhile, hard(fast) trail riding, etc.
Im happy for the most part with how its held up. The fuel tank still has me ticked though.
Old 07-15-2016, 09:20 PM   #13
bogieboy's Avatar
my 2 cents... this is why they are shearing....wheelies... I sheared 3 sets of those wheelieing.... I endes up supermoro conveeting with ninja 250 wheels and a cush hub that doesn't use stipud little pins.... I forget where I got em but I found some hardesned larger diameter pins somewhere... fit the big holes in the sprocket... didn't have issues with that....
Old 07-15-2016, 01:29 PM   #14
Ariel Red Hunter's Avatar
Thanks guys.
Looking at your picture, it appears that the sprocket is bearing on the threaded end of the studs. If that is so, I'm not surprised they sheared off. The load must always bear on the unthreaded part of the studs. Find longer shanked studs, even if you have to use washers to get the nut tight.
Old 07-15-2016, 01:41 PM   #15
Its very odd though, if you refer back to my previous pictures, my stock ones broke on the smooth stud side. The threads are fine, but I know what your saying.
http://www.chinariders.net/showthread.php?t=16797
It seems to be a specialty part... is there a common replacement?
