Engine knock sound, thoughts?
Seems like in hogging this forum so bear with me
Zong is making engine knocking sound, its a lot quieter now so this sound is very exaggerated, but still a definite knock there, She starts/idles/rides fine its when in idle you hear this , and low-medium revs Im suspecting timing? Running boosted fuel Video was piston was new fyi Last edited by b44; 07-25-2016 at 05:30 AM. |
rpm way low
one of your adjuster nuts fell off the valve exhaust leak / |
Try putting your hand over the exhaust and pay attention to how the noise changes. If it is exhaust leak, the sound should change.
Pull the clutch lever and see if it changes. Check the valve clearances. |
Ok this is video taken today, you can hear knock/rattle every 2-3 seconds exhaust sounds are gone its got a kind of possible tapping sounds
Appreciate the help fellas |
I'm thinking along the lines of the other 2 folks, did you ever check the valves yet or maybe you did what everyone here has done at least once before... set the valves on the wrong stroke/T line?
It makes a really loud "Tappy Tappy Tappy" sound when you do the valves on the wrong T-line ![]()
Yes double checked valves, no change in blocking exhaust off,clutch in no change either, i raised idle speed has quieter noise still there on rev up ,think ill have to look at timing? Not sure if i should advance or retard, im thinking retard
What is boosted fuel?
