07-05-2016, 09:35 PM | #1 |
Hawk Died On Me. HUH???
on the way home from work today the hawk just suddenly quit running. no indication of problems prior to the event. I was running it hard, full out at 7500 RPM. I recall noticing that I was at 59 MPH at 7500 RPM with a 17/50 sprocket set (in case anyone is interested).
the motor quit and even though in gear coasted to a stop. Once stopped, I tried starting it. it would sputter a short bit but die. after a few tried, what I discovered is that it would run at idle, but I could not rev it up without choking it. could have been fuel starvation. Called the girlfriend who brought my truck and trailer to me. loaded the bike up. tried starting it again, just for fun. idled fine, but could not rev it up. Drove home, which was only a 5 mile ride. Once at home, I decided to try starting it again. Started right up and revved up like nothing had ever happened. WTF???!!! I have not done anything to it at this point besides pull it into the garage for the night. Anyone have any troubleshooting ideas or tips that might help deduce what was going on?????? I initially thought that perhaps something had vibrated loose in the carb, perhaps the main jet or something. pilot was working as it would idle for minutes without any indication of problems. lift the slide just a bit and she'd choke and die. I thought perhaps the float had stuck or something. wrapped on the carb and tried starting it again. no luck. I also disconnected the fuel to see if it was flowing. it was. I also popped the cap off the tank to be sure there was no vapor lock. I'm going to pull the carb, cause I want to swap some jets anyway. |
07-05-2016, 11:24 PM | #2 |
Would a bad CDI cause this? Or maybe a connection came loose?
I would check the carb stuff first though. |
07-06-2016, 04:53 AM | #3 |
I had the same symptoms as you describe where it would be fine one minute and then just die. Wait about an hour an ran like it never happened. I figured my Hawk just didnt like going to work bc it usually happened in the morning on the way there. After continuous WTF moments, it turned out it was my ignition coil. Visually it looked all good but the connection just wasnt up to par.
07-06-2016, 05:09 AM | #4 |
Heat....
7500rpm & carbs at the back with very little air flow.. is there a heat riser block between the head & carb? heat riser block.... bit of nylon/plastic to stop heat traveling back to the carb..... PS... if it has a rubber flange a heat riser is not needed...
07-06-2016, 08:18 AM | #5 |
Fuel line? I had a KLR that did the exact same thing. It had a very cheap fuel line and when it got hot it would collapse and crimp at the bend. Replace it with a better quality line and never had problem again.
Mark 2015 Haosen Hawk 250 2014 CRF250L 2014 CB500X Rally Raid |
07-06-2016, 08:30 AM | #6 |
I pulled the fuel line at the petcock, but not at the carb. Note to replace it though just in case.
07-06-2016, 08:29 AM | #7 |
rubber flange.
07-06-2016, 08:31 AM | #8 | |
07-06-2016, 08:33 AM | #9 |
thanks everyone for your help and replies!
I'll replace the fuel line, check the coil and I'll also be taking the carb apart to check it since I want to rejet anyway. Work on Thursday, so I'll try running the pee-wad out of it again! |
07-06-2016, 10:46 AM | #10 |
Sounds like a CDI to me. They get hot, quit, restart when cool. That would be my guess.
07-06-2016, 10:58 AM | #11 |
Maybe it is breaking down internally, and is shorting out at higher rpm. It will be interesting to hear the solution.
07-06-2016, 11:21 AM | #12 | |
I have a spare at home, just in case. Dirt cheap.
07-06-2016, 11:28 AM | #13 |
I would run it until it quit again then quickly reach down and shut off the petcock. Then open the drain screw on the float bowl and see if an ounce or two of gas drains out. If it does, fuel flow to the carb is OK.
Then pull the spark plug and check for spark. Then put thumb over the plug hole, hold tight, crank engine, see if air escapes past your thumb. |
07-06-2016, 12:37 PM | #14 |
What replacement CDI do you recommend?
07-06-2016, 01:39 PM | #15 |
It depends on what CDI you have. AC or DC. Look at the connector and buy one with a like connector configuration. It should also be marked.
Here's an example of the many available on Amazon. https://www.amazon.com/4-stroke-Hori...+dirt+bike+cdi
