Old 07-05-2016, 05:08 PM   #1
Jayman77   Jayman77 is offline
Jayman77's Avatar
TT250 carburetor?
Has anyone thought of a better carburetor for the TT250 or is the one it has good.
2016 TT250
2014 NSS300 FORZA
2014 UN200 BURGMAN
Old 07-05-2016, 05:25 PM   #2
This is what I have on my other CG motor in my Rhino and it works like a champ.
https://www.amazon.com/MIKUNI-VM26-C...M26+%2830mm%29
Old 07-05-2016, 05:38 PM   #3
Jayman77's Avatar
Just curious to what makes them different what makes this carburetor better than the stock
or is it just more user friendly
2016 TT250
2014 NSS300 FORZA
2014 UN200 BURGMAN
Old 07-05-2016, 06:24 PM   #4
simonjester   simonjester is offline
simonjester's Avatar
Also for those of us with less experience, does the one in the link plug and play or do you have to mess with it to get it to fit?
2016 CSC TT250
Old 07-06-2016, 10:06 AM   #5
On my Rhino, it was plug-n-play. The mounts were the same distance apart on the head flange. I'll need to measure the TT and see. You just had to change the slide on the cable (the Mikuni's is larger) and hook it up, not counting jetting options. Since the TT doesn't have a cable choke, no biggy there either.
The stock carb looks ok. I was checking it out last night but it appears the Mikuni is a larger diameter carb. I'm not sure what size carb the TT comes with but the slide looks small in diameter, which would translate to a smaller diameter bore as well.
Another nice thing about the Mikuni is jets are readily available and it's a popular model. I'll probably end up swapping over to one when I do the pipe down the road. I'm not sure of the diameter of the air inlet snorkel on the stock box. If it's too small, I'll go to a pod filter. Mrs. 2LZ won't be submerging her TT anytime soon.
Old 07-06-2016, 12:44 PM   #6
'16 TT250   '16 TT250 is offline
The TT's carb is tunable and I think they carry jets at CSC. One of the guys there told me they'd played with them a bit and got good results with going richer on the main jet and leaner on the needle setting. That should keep part throttle cruising from being too rich and give an increasingly richer mixture as the throttle is opened. He didn't know the jet size and I forgot to ask the mechanic.
Old 07-05-2016, 09:33 PM   #7
pcspecialist   pcspecialist is offline
Doesn't the TT ship with a fully tunable carb? I was under the impression they even have a tutorial on tuning it, sell the jets, and the needle has a clip with multiple positions.
Old 07-06-2016, 02:41 AM   #8
pete   pete is offline
pete's Avatar
these are very good....no harder to jet than any other carb...
http://www.aliexpress.com/item/SUPER...999.447.4cLz4M
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 07-06-2016, 02:50 AM   #9
Jayman77's Avatar
Have you used this it looks good and is ajustable but damn it is only 20$
I am a cheap guy but even I suspect a 20$ carburetor
what do you know about the TT250 stock carburetor
just trying to get all info I can about this subject
2016 TT250
2014 NSS300 FORZA
2014 UN200 BURGMAN
Old 07-06-2016, 03:55 AM   #10
pete's Avatar
A 32mm on my Yamaha TTR250....Also have one on my 1977 Montesa Cota 348 trials bike..
main & pilot jets are $10 for a pack of 10 each.. sizes of your choice...
They are made in China copyed of a Tiwanese OKO carb....
09 XT660R ...
06 TTR250 ...
81 Honda CT110...
Old 07-06-2016, 09:03 PM   #11
humanbeing's Avatar
I am a cheap guy but even I suspect a 20$ carburetor ...
Denfienfly not for cheap guy. Good responds = burn more fuel = dries the wallet
Old 07-06-2016, 04:04 AM   #12
zingshoen   zingshoen is offline
zingshoen's Avatar
that s a good price! just make sure you have the right flange for the honda derived motor, which is a bolt on carbie, the yamahas are the spigot type.
1971 Garelli Gulp 50cc with open ports and 16 mm Bing Carbie + 1980 Honda XL 223 ZS + 2007 Zongshen LZX200G + DR400SM
Old 07-06-2016, 04:30 AM   #13
pete's Avatar
there are rubber flanges on AliExspress... Wheather they are the right ones for
your motor i have no idea... but worth checking out..may get lucky...
On the TTR250 i had to make a 20mm thick nylon block to go between
the flange & motor to get the carb back far enough to get it into
the air boot from the air cleanner...
09 XT660R ...
06 TTR250 ...
81 Honda CT110...
Old 07-07-2016, 11:08 AM   #14
At 3000', I've not needed the choke yet. Starts right up. Just a tad lean for a minute but clears up quickly.
Rojo, did Gerry mention the bore size of the stock carb? I didn't see it in any specs. It looks small, according to the slide chimney and the casting on the head side...like a 32 or 34 maybe. Just guessing.
Old 07-07-2016, 12:55 PM   #15
rojo_grande   rojo_grande is offline
rojo_grande's Avatar
Gerry didn't mention it and I didn't ask on the bore size.
I'm still getting a little hesitation at 3/4 to WOT at the moment with the 102 main. Seems better than the 108. But I'll still tweak some more. Got 650km/400 miles on the bike now and just installed a new iridium spark plug last night. Hope that will smooth it out some.
Rojo
'15 RX3 (Rojo's)
'15 RX3 (marzhere's)
'16 TT250
