Old 06-29-2016, 07:34 PM   #1
Madcliker75   Madcliker75 is offline
Madcliker75's Avatar
Question on Hawk and Shinko 705's
I wanted to get the Shinko 705's for my hawk. Can anyone tell me if the 120/80-18 will fit the stock rear rim of the hawk? Also would I be getting the 90/90-21 Shinko 705 for my front?
Thanks!
Hawk 2015
Old 06-29-2016, 07:40 PM   #2
w0ss   w0ss is offline
I don't believe the rear 705 is offered in the hawk size. I believe some have used it anyways and it worked for them. I went with the 244 but I wanted a 50/50 tire.
Old 06-29-2016, 08:17 PM   #3
hertz9753's Avatar
It comes in a 4.10P-18TT for the rear which would be the proper width but I don't know the side wall height.
Old 06-29-2016, 09:48 PM   #4
chuck   chuck is offline
Thanks!
Hawk 2015
Yes the 120/80-18 and the 90/90-21 will fit the Hawk.I put a little over 400 miles on them so far with very good results on the road.
Old 06-30-2016, 10:29 AM   #5
Thank you very much this is the definitive answer I was looking for but could not find in previous threads
Hawk 2015
Old 06-29-2016, 10:34 PM   #6
pcspecialist   pcspecialist is offline
Already discussed in an earlier thread: http://www.chinariders.net/showthread.php?t=16337
Old 06-29-2016, 10:37 PM   #7
I should add, I had 705s on my BMW F650 Funduro and absolutely hated them on the trail. You might as well purchase 100% street tires. I wouldn't use anything less aggressive than the 700 if you plan on spending even a moment on the trail and nothing less aggressive than the 244 if any mud.
Old 06-29-2016, 10:49 PM   #8
I was debating the 705 vs the 244. I ended up going with the 244 but I saw some youtube videos of the 705 riding some decent trails. As long as they were dry it seemed to be ok. Looked like it was slicks in mud though. They also seemed to be questionable on the rear size. I found some threads saying they worked while others saying they were not the correct size.
Old 06-29-2016, 10:51 PM   #9
as long as the trail is dry, 100% street tires will be ok. With the 705's, my F650 would come out from under me even when I babied it on green grass. You can find 100% street tires that grip green grass better than a 705. I think the tread pattern is worse than 100% street at everything but mud...... and it is still useless in mud.
