Old 04-27-2016, 07:38 PM   #1
detours   detours is offline
detours's Avatar
Improve brake light intensity?
Has anyone noticed that the RX3's brake light isn't much brighter than the tail light? The tail light could be brighter too, but I really like my brake lights to pop.
I first noticed this when I was following DanKearney on our ride a couple of weeks back. I could barely tell when he was braking because the transition is a blink-and-you-miss-it microsecond and the brake light isn't bright enough to convince you it's not just the tail light.
Does anyone know a way to bump up the brightness of the brake light? Like maybe a resistor we can remove or change out?
Red 5 standing by!
2015 CSC red RX3 with 19" front wheel, Shinko 804/805, skid plate, tall seat, 13T/45T sprockets, progressive shock, Winyoochanok windshield, GENSSI LED headlight, SW-Motech tankbag, Shorai Lithium battery
2014 Ural Patrol
Old 04-27-2016, 08:14 PM   #2
tinman tim   tinman tim is offline
tinman tim's Avatar
I didn't do anything with the stock rear light, but I did add an extra LED brake light.
It's called the 'Soundoff mini 3led'. Has 33 different flash patterns
Mounted on the flat just below the taillight, just have to remove the reflector
I thought it was kinda pricey till I got it powered up, then realized it's worth every penny! It's almost painful to look at. You won't be disappointed
Old 04-27-2016, 11:17 PM   #3
Eco Mouse   Eco Mouse is offline
Eco Mouse's Avatar
I replaced both of my rear tail lights on my KLRs with this:
http://www.customdynamics.com/Images/gen_200_new.jpg
But I haven't looked into what kind of light base the RX3 takes yet.
Old 04-28-2016, 01:46 AM   #4
RedHawk47   RedHawk47 is offline
RedHawk47's Avatar
On the CSC Baja trip I was following a bunch of other RX3s an also noticed that there wasn't much difference in the brightness of the brake light over the tail light. I was thinking that an improvement would be to have more LEDs in the light unit that came on only when using the brake - that would change the pattern of the lights and would indicate a change.
There are several options. I like the P3 lights from Skene Designs - they can be set to flash four times when you apply the brakes; they then go steady until you let off the brake. They also function as tail lights, with a flicker function.
My current favorite is the Volo light. It is a license plate frame with tail and brake lights. The difference is that the brake light is not operated by the bike's brakes. It is operated by an accelerometer that senses when you slow down. When you slow down by letting up on the gas or gently braking the brake light on the Volo will flash. If you brake hard the light will flash faster. Easy installation - uses power from your license plate light. http://vololights.com/
http://www.revzilla.com/motorcycle/v...or#reviews_tab
Dan
CSC RX3 Cyclone, CSC TT250, Moto Guzzi V7 II, KLR650
Old 04-28-2016, 07:26 AM   #5
That looks like a nice LED assembly. That unit has numerous flash patterns available; which one did you choose?
https://www.soundoffsignal.com/produ...e-mount-light/
http://sirennet.com/store/product/so...ed3-mini-light
Old 04-28-2016, 01:34 PM   #6
Did you connect the LED3 Mini light to the power input for the rear brake, and does the light illuminate only when the rear brake is applied?
Old 04-28-2016, 05:50 PM   #7
tinman tim's Avatar
Yes I went directly into the plug under the passenger seat to tap into the brake light wire. It's way to bright to have on as a tail light as it's not dimmable.
I chose the rapid flash constant pattern, so as not to be construed as an emergency vehicle. Law enforcement around here can be sticklers on stuff at times
Old 04-28-2016, 10:21 PM   #8
Thanks for the reply, Tim. I assume you activate the LED3 Mini when you press the rear brake pedal; am I correct? The LED3 mini has either 16, or 32 flasher patterns. Do you remember the number of the rapid flash pattern?
I think I am going to follow your example, and install the LED3 mini; I like it best of all the options.
Old 04-29-2016, 08:30 PM   #9
tinman tim's Avatar
Works with either brake applied ofcourse, any time the brake light comes on. Not sure what number it is on the flash pattern. Real easy to cycle through them. With light 'on', simply ground the white wire momentarily. This changes the pattern, & saves it until you change it. Pick the one that works best for you.
Old 04-28-2016, 06:27 AM   #10
Ron B   Ron B is offline
Ron B's Avatar
In my harley i used one like this from walmart. brake light flashes when when brakes applied.
Wingless Hawk, 2016 orange RX3, 97 wide glide,2003 KLR
Old 04-28-2016, 11:07 AM   #11
RedHawk47's Avatar
Doesn't work on the RX3 - LED taillight; no place to plug it in.
Many of that type light are labeled "off road use only" or something similar.
Dan
Old 04-28-2016, 07:31 AM   #12
Here are several videos showing the design and operation of the SoundOff LED3 Mini, a.k.a. the SoundOff EL3SNR.
Old 04-28-2016, 07:31 AM   #13
Old 04-28-2016, 07:46 AM   #14
For about the same price as the SoundOff EL3SNR, you can also get the Hyper-Light Flashing Brake Light.
http://www.hyperlites.com/stdsf.html
To reduce cost, you can choose either the Universal, brake light only kit, or the S16, brake light only kit. However, other kits with more options are available.
WebBikeWorld did a nice review of the Hyper-Light brake lights.
http://www.webbikeworld.com/lights/h...yper-lites.htm
Old 04-28-2016, 07:51 AM   #15
Here are several videos demonstrating the operation of the Hyper-Light LED system.
