Warning: Fractured Wheel Bearing
Several days ago I replaced the Shinko 244 tire on my rear wheel. I always inspect every part of the wheel every time I remove a wheel, or replace a tire. The rear hub has two bearings, and the bearing near the rear sprocket was completely fractured.
![]() ![]() The bearing on the other side, near the brake rotor, was notchy, and ready to fail. I replaced both Chinese bearings with Japanese bearings, which I had in stock for the original hub of my Zongshen ZS200GY-2. ![]() ![]() The stock bearings have very little grease in them. I packed the new Japanese bearings with extra grease before I installed them. ![]() ![]() I will post photographs of both Chinese bearings tomorrow.
Spud, please post bearing size or code, thanks
Post Edited to Correct Errors
Since you are in Argentina, you might have an earlier version of the rear hub. It contains the following bearings. Rear Hub Bearing Sizes Rear Hub Bearing, Sprocket Side: 6202 2RS Rear Hub Bearing, Brake Rotor Side: 6302 2RS Sprocket Carrier Bearing: 6004 2RS However, CSC, Cyclone RX3 motorcycles sold in the United States contain the following bearings. Rear Hub Bearing Sizes Rear Hub Bearing, Sprocket Side: Two 6202 2RS Bearings Rear Hub Bearing, Brake Rotor Side: Two 6302 2RS Bearings Sprocket Carrier Bearing: 6004 2RS
Spud "Never argue with an idiot. He will drag you down to his level, and beat you with experience." ![]() 2015 Zongshen ZS250GY-3 (RX3) 2006 Zongshen ZS200GY-2 (Sierra 200) 2005 Honda XR650L 2004 Honda CRF250X 1998 Kawasaki KDX220 Mods made to my Zongshen ZS200GY-2: http://www.chinariders.net/showthread.php?t=6894 Last edited by SpudRider; 05-30-2016 at 02:14 AM. |
#4 | |
Do you have a link where I can buy the higher quality Japanese bearings? |
#5 | |
![]() ![]() http://www.chinariders.net/showthread.php?t=5243
I found NACHI brand Japanese bearings on Amazon, in the sizes you listed. They were about $7 each, as opposed to $1 - $3 for the other brands.
What is the size for the front wheel? I'll just make a go of it, and buy all 5 right now. |
If you replace a worn bearing before it fractures, you can easily remove it. I prefer to drive out wheel bearings using a Motion Pro bearing driver and split collet. The bearings in the rear wheel of the RX3 can be removed using the following parts.
![]() http://www.motionpro.com/motorcycle/partno/08-0260/ ![]() http://www.motionpro.com/motorcycle/partno/08-0268/ ![]() Just in case someone hasn't used this method to remove wheel bearings, here's how it works. ![]() ![]()
I have bought individual drivers and split collets for the different sizes of wheel bearings in all my motorcycles. However, if I were buying the bearing drivers today, I would get the Pit Posse Motorcycle Wheel Bearing Remover Kit, PP-1692.
![]() http://www.amazon.com/Pit-Posse-Moto.../dp/B005SUVQUK http://www.ebay.com/itm/Motorcycle-W...ZyimIg&vxp=mtr
You can decipher the bearing code by reading the information at the following links.
![]() http://www.gizmology.net/bearings.htm http://www.mymachineinfo.com/2015/07...ion-guide.html http://www.engineerstudent.co.uk/bea...explained.html http://www.engineerstudent.co.uk/bea...plained_2.html For example, a 6202 2RS bearing has the following features. 6 = Deep Groove Ball Bearing (Single row) 2 = Light Duty Bearing 02 = Inner Race Diameter of 15 mm 2RS = 2 Rubber Seals
Wheel bearings fail more quickly when they lack sufficient grease, and every wheel bearing I have examined suffers from this deficit.
![]() ![]() ![]() Therefore, I always pry off both rubber seals, and add more grease to the wheel bearing before I install it. ![]() ![]()
Using a bearing driver makes it much easier to remove old bearings.
![]() ![]() Just make sure you get the correct size driver and collet for the bearings you wish to remove. ![]()
#14 | |
#15 |
Lee, I do also, my bearings have 16K km on them and they're smooth as silk, but as you said it's cheap insurance to change them anyway.
