Old 04-05-2016, 07:21 PM   #1
boostitall   boostitall is offline
Question Hawk 250. What engine is its clone of?
Hi Im new here. but iv been lurking for a while and I can't seem to find what engine the Hawk 250 is a clone of. I am under the impression its a Honda But which one? or am I comleatly wrong lol.
FYI I want to know so I can know which parts I can use nambrand and aftermarket parts with.
Thanks in advance
Old 04-05-2016, 08:03 PM   #2
Mudflap   Mudflap is offline
Upsized clone of a Honda CG 125.
Old 04-06-2016, 08:45 AM   #3
BARLOW   BARLOW is offline
BARLOW's Avatar
do you know if this also true of the counterbalanced engine (only with the added shaft)?
Old 04-06-2016, 10:33 AM   #4
The CG motor has to do with the pushrod design (as opposed to OHC with a chain) for longevity and utter lack of any maintenance that most of these see around the globe. They were built to be durable with good torque, not necessarily powerful. When the counterbalance was added, I'm not sure...........
Here's a great read...
http://world.honda.com/history/challenge/1975cg125/
That said, I've had 4 CG motors now, all non-counterbalanced. I'm looking forward to the TT250 to see if there's any discernable difference.
Old 04-06-2016, 12:28 AM   #5
Welcome!
You'll find Wikipedia info on the CG125, and you'll discover that it was never distributed in the US or Canada.
Old 04-06-2016, 03:09 PM   #6
So it being an up scale means there aren’t any performance parts for the engine? ( things like cams, bore kits, etc?)
Old 04-06-2016, 03:26 PM   #7
I know my Q motor (OHC Suzuki-type) had Suzuki cams from "Hot Cams" that would drop right in there were a few past members modding them for power but I've not seen anything like that for the CG motor. Being pushrod, I think a torque cam would be nice. Maybe someone can get a cam and send it to a grinder to have a custom lift and duration set up???
Old 04-06-2016, 03:37 PM   #8
hmm I will have to look in to that, thanks.
assuming the jug is big enough would it be possible to bore it to a true 250 and drop a Honda piston in?
Old 04-06-2016, 05:05 PM   #9
Honda never made a CG250, only 125 and 150, and those were workhorse engines not designed to make a lot of power. There is only so much you can do with a pushrod engine with a single lobe cam.
The counterbalanced engine is essentially the same as the non counterbalanced engine. Most parts are interchangeable within the same manufacturer but not necessarily between manufacturers.
Old 04-06-2016, 06:09 PM   #10
humanbeing's Avatar
Honda never made a CG250, only 125 and 150...
Honda DIDN'T made any 150 (62mm bore) ***bottom hole is smaller*** http://www.chyangwa.net/forum.php?mo...authorid=75082 Chonda (kick& e-start) "cg" is based from Kymco...
Taiwan (58.5*49.5) http://artok.myweb.hinet.net/dx-4.jpg | Philippines (58.5*57.8) http://www.hondamotorworld.com/node/15
Old 04-06-2016, 05:12 PM   #11
oh ok cool. Still I can't leave well enough alone when it comes to modding engines and bikes. ill have to do more research but if there are any known mods besides upgrading to a different 30mm carb would you be so kind as to point me in the proper direction?
Old 04-06-2016, 07:48 PM   #12
chuck   chuck is offline
Replace the anchor with a fmf or Pro circuit t4 exhaust.It Sounds much better and it pulls stronger.
Old 04-07-2016, 10:36 AM   #13
Do you know what year and model to order for the Pro Circuit T4? I love the FMF TC2 but am always on the prowl.
Old 04-07-2016, 05:23 PM   #14
It's for a 2006 crf230.It's a pretty good fit. I posted a few pictures under Hawk 250 exhaust.
Old 04-06-2016, 10:38 PM   #15
ok thanks
Toys n bikes, 110 Monster aka Zombie,
Yamaha Blaster fully set up to race aka typhoon,
traded typhoon for a KTM 520 ex that is my current ride aka Jennifer,
will be getting a Hawk 250 as soon as the ktm is sold so soon.
enine, hawk 250, mods
