Old 03-28-2016, 02:45 PM   #1
Riley W   Riley W is offline
I think there's a problem with my clutch
I recently bought a new Lifan 200cc engine with hopes of swapping it for my old engine on a homemade go kart. So far, I've been very successful and I'm almost ready to drive it. The only problem left is the shifting/clutch. I built a shifter kart-style shifter on the kart and I bought a normal clutch cable, that works fine. The problem comes when I start the engine and put it in any other gear beside neutral, the driveshaft starts to spin at idle and when revving (obviously) My first thought was that the clutch was engaged, but when I looked at the clutch lever, and played with it, nothing happened. The clutch lever is loose and it doesn't feel like it's doing anything. I did buy pennsoil 10-30 4 stroke oil, which I think could be the problem. I just ordered some of this oil, which should be for a wet clutch http://www.amazon.com/gp/aw/d/B00DJ4..._rd_i=15719391
I can send a video of the kart and how the engine is acting if needed.
Old 03-28-2016, 02:50 PM   #2
Adjuster's Avatar
Your talking about with the kart in the air and the tires off the ground correct? I don't think that's so unusual for the tires to spin a little. But there should be no resistance if you grab a hold of the tire and stop it from spinning or apply a little brake pressure.
Old 03-28-2016, 03:14 PM   #3
Yea that was the first thing I tried, but there's a lot of resistance, I applied enough brake pressure that the engine died.
Old 03-28-2016, 03:15 PM   #4
Old 03-28-2016, 06:13 PM   #5
Adjuster's Avatar
Yeh that has to be in gear. Are you able to shift the gears? Are you able to put it in neutral?
Old 03-29-2016, 01:04 AM   #6
Yes I am able to shift through all the gears.
Old 03-29-2016, 01:31 AM   #7
Oils which are labeled "energy conserving" are bad for any vehicle with a wet clutch, meaning most motorcycles. Essentially all 0w-20, 5w-30, and 10w-30 oils are energy conserving, and should not be used in your bike.
http://www.calsci.com/motorcycleinfo/Oils1.html
Old 03-29-2016, 02:39 AM   #8
Thanks, I just wanted to make sure that was the only problem, I ordered valvoline 10w-40 motorcycle oil, which should be perfect right?
Old 03-29-2016, 05:50 AM   #9
The 10W/40 motor oil will work with the wet clutch in your engine. However, it might take a little while for the 'energy conserving oil' to be displaced by the new oil.
Old 03-30-2016, 11:22 PM   #10
Today, the oil came in the mail and I exchanged it for the old oil, the first thing I did was let it run for a while, about 20 minutes at idle. Is there anything else I could do to help get the clutch free?
Old 03-31-2016, 02:59 AM   #11
If you can operate the cart for a few miles, the new oil will gradually replace the old oil. If the clutch won't work, you can remove the clutch plates and soak them overnight in the new engine oil before replacing them.
Old 03-31-2016, 04:44 AM   #12
humanbeing's Avatar
Originally Posted by SpudRider View Post
...If the clutch won't work, you can remove the clutch plates and soak them overnight in the new engine oil before replacing them.
Old 04-01-2016, 05:36 PM   #13
I've been running the kart for about 1hour each day for the past 2 days. I haven't seen any results, no matter what gear I'm in (besides neutral) the driveshaft is spinning, when I try to brake the engine either dies, or nothing happens when I brake. Same problems even though I switched out the oil. do I have to open up the engine and do any work with the clutch? Or will the engine need more time running with the new oil? Opening up the engine is a problem for me as of right now. So I would prefer not dismantling the clutch to replace it or soak it. Thanks.
Old 04-02-2016, 02:43 PM   #14
Bump
Old 04-02-2016, 04:01 PM   #15
Bruce's   Bruce's is offline
I just looked at your. video ,it shows you easily moving the clutch lever on top of the transmision with your fingers ,you should not be able to do that .I would take the right side engine cover off and see what's going on inside .I have the same engine in a dirt bike ,I just went out and tried moving it with my fingers and there is no way you should be flipping it around like that ,it takes a lot of effort just to get it to move the tiniest little bit .
