12-15-2015, 08:50 PM | #1 |
RX3 Shut off while riding
OK OK OK....
So today for about the 6th time my RX3 just completely shut itself off electrically while riding. I'm just riding along, the tach goes to zero, the engine shuts off and the red engine light starts flashing. Every time this has happened the circumstances have been similar. Just leaving the house or work, get about 2 blocks away and then it dies. Roll to a stop, pull in the clutch and try to restart it. ( I've noticed the RX3 doesn't really like to start while in gear and the clutch pulled in ) Shift it into neutral and after a few cranks she generally fires right up and I ride on. The first time it happened I didn't really think about it too much but now that its happened so many times it's starting to concern me more. Thank god this hasn't happened while riding on the highway or through town in busy traffic. I have been racking my brain trying to think of any thing that I may have done to cause this issue. The only thing that I can think of is when I was checking my air filter a few weeks back I found a section of the wiring harness was in the way of the filter cover making it really painful to get to. I noticed a small hook or slot on the frame where it looked like the wiring harness belonged so I relocated the harness to that position and re zip tied it. I looked over all the connections and I didn't notice any thing loose or unplugged. Other than that I haven't messed with anything electrical at all on the bike. So has anyone else had this issue or anything similar? |
12-15-2015, 08:59 PM | #2 |
Sorry to hear about the shut off problem...can't help you there.
I did the same thing with the wiring harness blocking the air filter. Now I'm thinking I should remove the harness from the hook in fear of it rubbing against the edges of the hook and causing an electrical problem. jb
12-15-2015, 10:08 PM | #3 |
Is the engine warning light flashing a DTC (diagnostic trouble code)? Have you checked the battery for low voltage, or a dead cell? Have you checked the valve clearances?
12-16-2015, 12:53 AM | #4 |
The battery is only a few weeks old and it came from batteries plus with a two year warranty. I haven't checked the voltage yet. I'll have to check that tomorrow. I did the valve adjustment about 500 miles ago. But that's interesting.... Because honestly I do not remember this problem before I adjusted the valves. So perhaps you're on to something? Maybe I should take another look at my clearances this upcoming weekend!
12-16-2015, 12:57 AM | #5 |
Also... I've done the diagnostic check and it didn't give me any blinking lights or do anything other than the normal display and start up procedure.
12-16-2015, 02:13 AM | #6 |
Good for you. I do recommend you check the battery first. If battery voltage is low, you will experience the problems you reported. If all cells of the battery are good, then you certainly should check the valve lash. Also, make sure the spark plug cap is securely attached to the spark plug. Please do keep us updated.
12-16-2015, 06:55 AM | #7 | |
http://www.rx3forums.com/forums/show...gnition+switch |
12-16-2015, 09:25 AM | #8 | |
Stalling and Air Flow Sensor
12-16-2015, 09:28 AM | #9 | |
12-16-2015, 12:08 PM | #10 |
I had mine cut out once a while back but only for a few seconds. My post on it is buried deep some where in the mega thread.
Turned out to be a bit of corrosion on the ignition switch contacts. Cleaned them up and smeared them in silicone grease, never had a problem since. The ignition switch comes apart pretty easily, without to much risk of springs, balls and contacts flying every where. I hope your problem is sorted as easily as mine was |
12-16-2015, 01:57 PM | #11 | ||
12-16-2015, 12:03 PM | #12 |
For the unfamiliar, you can buy mass airflow sensor spray cleaner at most auto parts stores. CRC makes such a product.
12-16-2015, 01:54 PM | #13 | ||
This sensor is located in the intake manifold, downstream from the throttle tube, but upstream from the fuel injector. The MAP/MAT sensor is shown inside the orange oval in the photograph below. Because of its location, orientation and construction, I don't think the MAP/MAT sensor needs to be cleaned periodically like a mass airflow sensor. For some reason, Andy's sensor was oily. It's good to check this sensor, but I don't think it's a common problem for this sensor to get dirty.
Spud "Never argue with an idiot. He will drag you down to his level, and beat you with experience." Mark Twain 2015 Zongshen ZS250GY-3 (RX3) 2006 Zongshen ZS200GY-2 (Sierra 200) 2005 Honda XR650L 2004 Honda CRF250X 1998 Kawasaki KDX220 Mods made to my Zongshen ZS200GY-2: http://www.chinariders.net/showthread.php?t=6894 Last edited by SpudRider; 12-16-2015 at 06:42 PM. |
12-20-2015, 03:41 AM | #14 |
Here are some more ideas. Check electrical connections to the MAP/MAT sensor, idle stepper motor, throttle position sensor, and emissions canister purge valve. Verify the emissions canister purge valve is functioning correctly. Check both of the purge valve hoses for leaks. Check the intake manifold and throttle body for air leaks.
