Old 12-04-2015, 10:51 PM   #1
jbfla   jbfla is offline
RX3 Stalled
EDIT: So far this appears to be a one time occurrence.
I have read about other RX3 stalling problems, and hoped it would be fixed by now.
It is not.
On my first 50 mile ride, I had to make a quick stop for a traffic light.
Let off the throttle and applied the brakes hard.
I stopped in time for the light, but the engine stalled.
The engine restarted after 3 or 4 cranks.
When the light changed, I started off, but the bike stalled again...in the middle of the intersection.
It would not quickly restart, and I had to push the bike through the intersection (with cars zooming around me) and to the side of the road.
The engine finally started after another 3-4 cranks.
There were no further incidents the rest of the trip.
This would not be a problem out on a trail....
...but in traffic, this could have gotten me killed.
None of my other, or previous bikes, have done this.
Hope there is not another occurrence.
jb
2014 XT 250........
Old 12-04-2015, 11:30 PM   #2
pete   pete is offline
pete's Avatar
Yamaha XT660s do that.... easy sorted on them...
usely the TPS & idle settings...
Could be something simular on the RX3...
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 12-05-2015, 12:13 AM   #3
rtking   rtking is offline
Jbfla, sorry to hear of the stalling issue. Not fun when it stalls in an intersection.
Give Gerry at CSC a call. Maybe he can have you try or check a few things to help identify or at least isolate a cause. Gerry is very knowledgeable and responsive.
Last edited by rtking; 12-05-2015 at 12:22 AM. Reason: Completed my thought process (posted before I completed my thoughts before)
Old 12-05-2015, 03:19 AM   #4
X2; I'd give Gerry a telephone call.
Old 12-05-2015, 07:04 PM   #5
Today I rode another 50 miles.
I found a deserted stretch of road, and tried to reproduce yesterday's stall.
After doing a half dozen hard, full stops from a cruising speed of 45 mph, and then accelerating back to 45.....
....I was unable to reproduce the stall that yesterday left me in the middle of the intersection.
Hopefully, it was a one time occurrence...one time is enough.
The rest of the ride was uneventful.
jb
2014 XT 250........
Old 12-05-2015, 11:26 PM   #6
AZRider   AZRider is offline
If you haven't yet done your first valve adjustment, you may want to check them even if the mileage is early.
George
2016 CanAm Spyder F3-L
Old 12-06-2015, 12:22 AM   #7
The bike only has 100 miles on it. CSC told me that a valve check is part of their setup procedure...don't know if that is true or not.
jb
2014 XT 250........
Old 12-06-2015, 01:50 AM   #8
I'm glad you had a nice ride. Is the engine warning light flashing a DTC (diagnostic trouble code)?
Old 12-06-2015, 08:34 PM   #9
Originally Posted by SpudRider View Post
.... Is the engine warning light flashing a DTC (diagnostic trouble code)?
No flashing that I can see.
To show fault codes is it:
...cycle the ignition key on-off-on 3 times...????????
Tried to reproduce the stall again today but was unable to.
Another 50 mile ride through the orange groves.
jb
2014 XT 250........
Old 12-06-2015, 09:05 PM   #10
Tried to reproduce the stall again today but was unable to. ...
Yes, the sequence is on/off, on/off, on; then look for the DTC.
Old 12-06-2015, 11:54 PM   #11
Jay In Milpitas's Avatar
Just a thought, JB.
Might check the battery voltage at rest and connections at the battery and also the starter solenoid.
There have been several battery failures (mine included) and I know that if the engine (ECU, fuel pump, coil, etc.) doesn't have adequate amps available, it will quit.
In one of the tutorials CSC talks about various connections to check. I'd start right at the battery itself.
Good luck, and glad you are getting some miles on it.
Old 12-08-2015, 07:47 PM   #12
Originally Posted by Jay In Milpitas View Post
Just a thought, JB.
Thanks for the suggestion. I meant to put the charger on the battery when I first uncrated the bike, but somehow was distracted.
Today I put the smart charger on the battery, and it checked out OK.
No further stalling during another ride.
Ready for the 200 mile oil change.
jb
2014 XT 250........
Old 12-09-2015, 12:50 AM   #13
How many miles have you ridden your RX3? Have you checked the valve clearances?
Old 12-09-2015, 12:36 PM   #14
mckayprod   mckayprod is offline
Just rolled past 1000 miles and I checked valves at the first oil change, 500 miles. The next scheduled valve check is at, what, 2500?
Old 12-09-2015, 08:03 AM   #15
kohburn   kohburn is offline
kohburn's Avatar
Originally Posted by mckayprod View Post
My experience with stalling:
if that is not common to all the rx3's (programming) then it would sound like a dead spot in the TPS.
