Canceled start procedure ( brake+start button cancelled.)
Standart procedure for start moto, key open + neutral gear offcourse + killswitch open + pull brake lever(front or rear ) + push start trigger or button and run.
Need help changed this procedure, i want how i can do , cancel or remove that " brake pull/press " option , i need just open red button+triger start button and run. New command panel mounted (original is damaged) , cables+connectors changed/replacement all news water ress. bonus ( lancet drill my hand deeper ![]() Last edited by Co2; 12-18-2015 at 12:31 PM. |
Ummmm,,,,,,,,,, okay.
I have to think a while and then get back to you. I promise. |
#3 | |
Thank you ![]() |
I forgot to ask, electric start or only foot?
Yep electric start procedure request brake pull/press ( brake lights on, brake switch on )+start triger or button.
İ want open contact key offcourse, + trigger start. |
CO2,
If I understand correctly, you want to eliminate the clutch safety. In other words, you want to be able to start the engine without pulling the clutch lever. Is that correct?
#7 | |
My model is brake's contact to start way. not clutch. if i cant pull brakes / not actived brake light, ignition not start, march motor worked but coil not i want solved that problem., this is a little secrty option, i cant need that my moto im only used. Rx3 how start first? clutch (clutch switch?) + start button? |
I believe he wants to eliminate the brake/safety start switch.
If you unplug the brake/safety switch and jumper the two wires will that do it? Or does that make the brake light constant on? / |
#9 | |
I must admit to doing one of these 0_o at those wiring pictures!
#11 | |
Am I the only one here that remembers when the only electrical safety devices motorcycles had were a charging light and a high beam indicator? Some of my bikes didn't even come with a neutral light. Sissy riders these days. ![]() |
#12 | |
This is a not a problem for electrcl system, this general modern motocycle's start procedure (childs, noobs safety or idk.) İm be disturbed that brake+start button motor start. Yep bike have all indicators, süpermoto version is legal traffic road on traffic id plate , dijital panel , (highbeam/low/turn signals/gear1-5/speed km-mile/tripmeter/ neutral /heat warn-but not sensor of heat^^) İm to bit a old thinks and classic , every time pull brake+start buton wrong for me my problem this. İ think this is a not simple theme, probably dijital panel , or CDİ sett that idk, maybe cant touch best methode. ![]() my sett new eletri circuit is work not any problem(not now/not yet^^ ) |
