RX-3 down....
My buddy who confidently bought an RX-3 right after I bought mine and loved it just called me and said he is stranded on the freeway.
Superdude,
Sounds like Andy on one of the other forums had the same issue. http://www.rx3forums.com/forums/show...ition-problems
'15 RX3 (Rojo's) '15 RX3 (marzhere's) '16 TT250 |
#3 | |
The only thing hes done to it or has messed with is he took the headlight bucket off and obviously the cluster to swap out the headlight bulb for an H4 and did the cut out and water hole as wall and did the cutout for it. Could of loosened an ignition wire up there that faulted and caused the ECU to throw a code and not let it start. Is a hard reset key off and on 5 times and that will clear? Plus how to tell if or what the code is?
There is a connector under the tank that might have worked loose, Chucks bike it was loose when he got it, took some search.g to determine why it wouldn't start
I had an O2 sensor fail at about 1,000 miles. Mine starting running rough, and then died once, but it started right back up. I received the replacement O2 sensor this week, but haven't installed it yet.
I'm not sure how to reset fault codes, but here's how to read them (I learned this on the side of the road while talking to Gerry from CSC): Start with the key in the off position. Turn the kill switch to the on position, and then turn the key ON, off, ON, off, ON and leave it on. If there's an error code, the engine light will begin to flash a pattern that reveals a four-digit code. The light will flash once for one, twice for two, and so on-however, 10 flashes equals zero. Mine flashed this pattern: 10, 1, 3, 2, which is code 0132, which indicates a faulty oxygen sensor. After it flashes the code, wait and see if it flashes another, or repeats the same one. The flashing sequence is supposed to pause for 4 seconds between 4-digit sequences. If your friend's bike powers up, have him try this and see what happens.
2009 TW200 (first bike ever, sold it!);2015 RX3 Cyclone in blue (first "big kid" bike ![]() |
Turn the ignition switch on/off, on/off, on, in rapid succession. Watch the engine warning light, and it will flash a diagnostic trouble code (DTC). Count the blinks. Here is a description from a Chinese service manual.
After confirming there is a fault, if open and close the key for three times switch three times, namely, open — close—open—close—open the key, the fault light will come to a flash code corresponding to the fault. And then through the fault code table identify the corresponding fault. With fault light reading fault, the rules of the flash code are as follows, for example, if the fault is the intake air pressure sensor is disconnected or the signal-side pin shorts to battery negative, after the key is opened and closed for three times the fault light will first flicker for 10 times on behalf of 0, flicker for 1 times on behalf of 1 after an interval of 1.2 seconds, flicker for 10 times again on behalf of 0 after an interval of 1.2 seconds, and after an interval of 1.2 seconds flicker for 7 times on behalf of 7 , namely, P0107.it is thus clear that other figures from 0 to 9 are expressed by the times of the flicker of the fault light except that figure 0 is expressed by flicker for 10 times. If there are other fault codes, such as fault P0201, which means there is a fault in the front cylinder injector, the fault light will continue to flicker P0201 fault code in 3.2 seconds after finishing P0107; if there is no other fault, the fault light will flicker P0107 and P0201 circularly, and then check the fault code table for related faults. Here is a chart of the Delphi MT05 ECU fault codes, in both decimal, and hexidecimal form. ![]() If you telephone CSC, they will also help you to decipher the trouble codes.
#8 | |
This is very helpful Spud. ![]() ![]() |
Start with basics.
It is also possible that it is just something simple, like a loose connector.
I suggest both of you review the tutorial from CSC. http://www.cscmotorcycles.com/Articles.asp?ID=261 Good luck with it and please report back. |
Or if your like me, he hit the kill switch accidentally. rj
Live Zong, and Prosper |
Went to pick it up tonight and went through all the electrical. First thing I did was the fault code check and there was no flashing lights. Everything checked out. Everything was connected and fuses were good. Stumped. Could it be fuel pump or efi if the fuel pump is priming fine? Might be fuel issues. Not sure. He's gonna call Gerry on Monday and prob take it to a shop Tuesday
Thanks for posting the update. Good luck.
Unless it's a hard failure of some kind from a new electronic part, I can't help but think it's something simple....like a battery connection or like others say, a connector somewhere that came apart. Also, the old rule of: "Look where the hands were last." comes into play. I'd check out all the headlight area electrical connectors closely. Disconnect and reconnect each connector. He may have bent a prong on a connector he had apart. It happens.
I had a brand new Victory die on me. 60 whole miles. Loose battery connection from the shop. If the EFI doesn't get full voltage, it shuts itself down to save itself. Hopefully it's something simple like this.
#14 |
Superdude,
Do you have an update for us? Was the problem diagnosed, and resolved?
#15 |
Hey Spud thanks for checking back. Gerry wasnt in the office until this morning hes off mondays. No resolution yet though unfortunately..Gerry offered to send a new fuel system and has been texting with my buddy having him check everything and so far its all the same no change. Lines are all good from fuel tank and plug is wet with fuel after cranking so hard to believe its a fuel issue. Next item he wanted to check was for a bent valve :/ so hes gonna check that tonight along with compression to see if its a motor issue. Can not imagine it would have a bent valve on a brand new bulletproof engine like this but crazier things have happened. Either way CSC is walking along with us (him) and helping figure out. I'll post updates on what happens next.
