Hello from a NOOB in Michigan
Hey everybody. Took the plunge and purchased what I was told a 1994 zonshen 250cc atv last night.. it's def. Rough around the edges.. but for 200 bucks I figured I'd give it a try... after returning to my buddies house and setting it side by side his coolster 250 mine is def. A smaller machine.. starting to think I might have been misled and it is not a 250.. it is full manual clutch but it does have linked front and back brakes.... if anyone can assist in identifying this beast I would appreciate it as I need to purchase some parts that are missing like a shift lever and possibly a left hand control switch. Seems to be constant hot now as no key switch is hooked up and starter button functions.. sorry if pics are small. . I copied them front the cl posting. I'll take more pics soon. I look forward to this being a great learning experience and a great source of info.
Welcome!
I like those quads, and I've worked on a few of them. The long control arms in the front prevent bumpsteer, which is very important at higher speeds. The engine is definitely not 250cc, because none of them are. They are always rounded-up, so yours is more likely to be either 223 or 229. If you give us the number that is stamped near the shifter, we can decode it. The brand of the ATV is unimportant; just search eBay, and keep your search terms generic, like "ATV clutch lever". The engine you have is based on the Honda CG125, but yours has been bored and stroked to something bigger. It is a pushrod motor, which means it only requires regular oil changes and an occasional valve adjustment. Very solid motor.
Welcome; we are glad you joined us.
![]() As usual, Weld has given you excellent advice. ![]()
Thanks guys.... your info was very helpful.. previous owner was a little ruff with it... front bumper is cracked at a weld and bent.. appears to be a fmf pipe from a different atv fitted... it does have a pz27 carb from quick inspection last night... it also appears that the pervious owner filled it with 2 stroke mix.. but I did get a minor backfire out if it just hooking battery up and hitting the fun button..... what plug is recommended to run in these? The plug that was in it looKS new.. but was only fingertight.. plus I like to make sure I have correct reach and heat range when I buy something used not running..
#5 | |
If that's the case, a Mikuni is much easier to find replacement jets for, and they're only about $40 shipped.
I might have to look into that... I'm about an hour east of the big lake.. but if I ever bring it to the dunes.... right now I just hope to get it up and running and something for me to tool around on or the wife to cut her teeth on... she's never been on a quad b4. Thanks again for all the info... keep it coming.... I like to learn as much as I can about atv ,motorcycles, basically anything with a motor..... or engine to be proper.... anything with combustion is an engine... electric or noncombustion is a motor... my electric gurus always correct me on that.... lol.. thanks again everybody....
#7 | |
Tell your electric gurus to go stuff a duck.
Should use an NGK D8EA plug.
welcome! I havebto ask, given the username... what mopar you race? I used to daily drive a supercharged 96 dakota....
No prob... thanks for the welcome... I have a srt4 acr and a 74 dart sport with a worked small block... 3.94 sure grip and 4 speed. And little bit of spray... lol. Srt4 is my summer daily and a ram 2500 for the salty months... what Gen dakota? Like an rt model with the 5.9?
nope, last of the box style gen2, that is if you count the first gen as 87-91, then the switch from sealed beams to streamlined and the v8 addition 92-6....LOL was runnimg 8psi from the blower...
Nice.... I always liked the box style.... I bet 8psI would be a blast in that... for a while I wanted to big block a box style.. but then practicality set in. Lol. Ill see if I can get some pics of the dart and acr from my computer.. I'm on a new phone and they are both in storage for the winter..
#13 |
#14 |
oh it was fun.... shut down anything slower than an srt4, standing start or the ricer highway stomp... either or....
heres a half throttle stomp just for fun... and a standing rev for giggles.... that always got looks at lights with the ricers.....hehehe |
#15 |
