Old 10-05-2015, 11:37 PM   #1
SlowJunk   SlowJunk is offline
Hawk 250 Data
Been helping a friend assemble one (Assembly Pictures - whenever it gets done)
If you consider it a combination of:
Honda NX 150 (Engine [maybe] and Some electrical layout - Battery on right side)
Honda NXR 150 ESD (2009) (Frame, Plastics, Attachments, Front Disk, Rear Drum, non-applicable ECM controlled engine - Battery on left side as on Hawk)
Then some torque values are:
Front axle is 44 Nm
Top bolt of of front shock clamp 22 Nm (NXR 150 has side-bolt clamp, Hawk has front-bolt clamp)
Bottom two bolts of front shock clamp 32 Nm
Swing arm is 88 Nm
Mono shock is 44 Nm top and bottom
Rear axle is 93 Nm
Handlebar Clamps 26 Nm (dot on clamps pointing at front wheel)
Front disk brake caliper 30 Nm
Hope this helps.
Old 10-05-2015, 11:55 PM   #2
Sicario   Sicario is offline
Front axle is 44 Nm
Swing arm is 88 Nm
Rear axle is 93 Nm
Hope this helps.
Thanks for the info! Helps a lot. You wouldn't happen to know who sells nxr 150 parts and ships to/within the US would you? I've been searching for days and so far I've only come across Brasilian sites who will only ship within Brasil.
Old 10-06-2015, 04:23 PM   #3
Thanks for posting the torque specifications.
Old 10-07-2015, 11:01 PM   #4
Hawk 250 Data again
Front muffler mounting bolt 26 Nm
Rear muffler mounting bolt/nut 26 Nm
Muffler clamp bolt (exhaust bolts to Cylinder head) 18 Nm
Screws the front muffler protector 14 Nm
Side stand nut 39 Nm
Luggage/Handhold Handles 35 Nm
Valve adjustment jam nut 14 Nm (now that's obsessive)
Front and top engine mount bolts 35 Nm
Bottom and rear (larger) engine mount bolts 60 Nm
Multi-bolt engine mount plates 35 Nm
I think, but am not sure,since I haven't changed one yet, that front sprocket bolts are 12 Nm.
Old 10-30-2015, 10:59 PM   #5
Carb Jets
I used these from aliexpress.com. Each link gets 12 main and/or 12 pilot. It took a week or so for the shipping (west coast).
http://www.aliexpress.com/item/Mikun...243535818.html
http://www.aliexpress.com/item/Modif...243554212.html
You put the sizes you want in the comments field when you check out.
Or individual jets here:
http://www.ebay.com/itm/351533316140...%3AMEBIDX%3AIT
http://www.ebay.com/itm/281814107323...%3AMEBIDX%3AIT
You can get front sprockets here:
http://www.ebay.com/itm/221723164918
As well as ordering the JTF259.17 for the front.
Note that the front sprocket that came off the Hawk has a 17.5 mm diameter to the keys and a 20 mm diameter for the shaft. The JTF259.17 has a 18 mm diameter to the keys and a 20 mm diameter for the shaft. Both seem to work fine.
Old 10-30-2015, 11:01 PM   #6
Front axle is 44 Nm
After reading the owners manual...
63 Nm for the front axle.
Old 10-30-2015, 11:04 PM   #7
Speedometer
Unless this HAWK is unique...
The HAWK 250 seems to have gearing for KPH not MPH.
Odometer appears to clocking at KMs and seems to be set for 17" front tire not 21" front tire.
Old 10-31-2015, 05:33 PM   #8
TXDSRIDER   TXDSRIDER is offline
TXDSRIDER's Avatar
I've noticed the same thing it's definitely showing more miles than its gone but I don't know about the speedometer I think mine is broken it seems to not read properly above 20mph.
Old 10-31-2015, 08:00 PM   #9
It could be that you have a Metric speedometer with a US face. It has happened before.
Go for a ride in a 30MPH zone, and see if it points to something higher, like 50. If you have GPS, use that for comparison. Most smart phones will utilize free speedometer apps, and they can usually be converted from MPH to KM/H.
Old 11-15-2015, 02:17 PM   #10
So I tried to go out on my motocross boots but could not get my toe under the shifter at all. I adjusted the shifter up to the point to where it could shift up but not hit the case. I need to find a shifter that sticks out farther and is longer than stock but the I can't seem to find those specs on any of the the websites they just say there for specific bikes. I could also try lower pegs . Any information on either of these would be appreciated.
This one will work. Unless you have exceptionally thick MC boot soles. It has about 1.5" greater reach and 1" offset over the stock lever.
http://www.ebay.com/itm/371437493889...%3AMEBIDX%3AIT
However, because the bolt head is on the top rather than the bottom the install requires you to take the front sprocket cover plate off to install. Not a big deal just two 8mm bolts.
The various aluminum (multi-colored) shifters on ebay also work, but are about 3/4" shorter.Albeit color coordinating with the bike. Look for ones with the 155 mm reach.
The shifter shaft spline is 11mm.
Old 11-21-2015, 04:12 AM   #11
Adjuster's Avatar
Very cool. Looks like it needs a shotgun sticking out of it.
Old 11-21-2015, 11:15 AM   #12
Genius! Now THIS is a perfect example of what being a China Rider is all about! An awesome tool kit for 4.00. Brilliant.....
Old 11-21-2015, 01:57 PM   #13
This is what I use: http://www.ebay.com/itm/OPERATOR-MAN...EAAOSwDwtUovqf
A little brake cleaner removes the symbols on the canister, and the two legs make for easy mounting. I've seen them bolted to the top of a trunk, underneath the carrying rack, on top or underneath panniers, strapped to forks...
The bonus is that one of these will fit inside: http://www.ebay.com/itm/MSR-30oz-Hik...8AAOSwrklVHurn That allows you to carry a little more fuel, just in case.
Old 11-21-2015, 05:00 PM   #14
trailrider   trailrider is offline
Good Find
I've used those Farm Supply canisters on my Suzuki V-Strom, Kawasaki KLR650, Kawasaki Versys and Honda NC700. Easy to install and very sturdy. I use rubbing alcohol to remove the yellow stencils. And the 30oz MSR fuel bottle fits nicely inside. And the canisters are very inexpensive.
Old 11-21-2015, 10:08 PM   #15
Nice job. I also used the Harbor Freight Welding Rod Container to make a tool tube for my Honda XR650L.
