08-27-2015, 09:38 PM | #1 |
Tao Tao ATM-50A1
Hi there,
So I recently came into possession of a scooter my friend didn't want to drag back home with him after graduation. It's a 2011 Tao Tao (I believe ATM-50A1 but I'm not sure, there's no real identification I can find.) Anyways I really want to try my hand at getting the most performance I can out of it without doing a big bore kit as I've read those have a high chance of causing damage to the engine. I've found some information here and there but not really a concise guide of everything that should be done. I don't have any experience with scooters and honestly don't even know how their engines work as I'm used to only working with cars and even then I haven't messed around in their engines that much either. Basically I need to learn how a scooter's engine works and also what can be done to maximize it's performance without major changes to the engine itself. Thanks for your time! |
08-27-2015, 11:27 PM | #2 | |
1:100% Taiwanese 2:Barrel (as bike's OEM)+ piston (BiG player of the industry ) + rings (BiG player of the industry) https://item.taobao.com/item.htm?id=35542063530 3:Barrel (OKish)+ piston (BiG player of the industry ) + rings (BiG player of the industry) https://item.taobao.com/item.htm?id=39034191868 4:Barrel (???) + piston (???) + rings (???) *Often on fleabay ... Chinese mechanic loves #2&3 cuz it won't F***ed their praise among customers ...
08-27-2015, 11:37 PM | #3 |
Could you elaborate a bit more? I don't know what you're trying to say about the big bore kits you listed. I also don't know why you listed those in that order either, is #1 the best and #4 the worst?
08-28-2015, 12:24 AM | #4 |
Yes, I think the order is from best to worst. I'd focus on #2.
Open the link in Google Chrome, and allow it to translate. You'll be pleasantly shocked by the prices. I wouldn't hesitate to poke out a 50 to 70 with a big bore kit. I haven't actually tried it yet. Read about my adventures with a 50 here: http://www.chinariders.net/showthread.php?t=9421
08-28-2015, 01:07 AM | #5 | |
08-28-2015, 11:51 AM | #6 | |
Go to Youtube, and search for setting valves on a 50cc scooter. While you're at it, search for scooter CVT and variator, so you can see how they work.
08-28-2015, 12:52 AM | #7 |
Buy from reputable seller that recommend in scooter forums since most don't show marks clearly on their picture ...
Rings also cames in different grade: regular [as stock]/ CID http://www.dongya.cn/en/intro.asp?aic=9 [~1.5x the cost of regular] | PVD (Physical Vapor Deposition) [~2x the cost of CID]
08-28-2015, 01:09 AM | #8 |
Oh also forgot to mention but the speedometer and odometer don't work either.
08-28-2015, 01:28 AM | #9 |
Those are chinese marketing terms
GY60:44mm ie.63cc | GY80: 47mm ie. 72cc
08-28-2015, 01:36 AM | #10 |
Oh okay, so I guess the GY80 sounds good, now where do I get the rings? I'd rather spend a bit more for higher quality if it'll reduce the risk of damage.
08-28-2015, 02:19 AM | #11 |
09-06-2015, 02:27 PM | #12 | |
09-08-2015, 12:38 AM | #13 |
08-28-2015, 02:43 AM | #14 |
Fantastic, can you confirm which options I want to select when purchasing for each of the items?
For the big bore kit should I get the "80 sets of cylinder combination" or "80 modified 100 sets of cylinder"? For the rings should I get the "GY6-60 Φ44"or a different one? Both of those I used the English translation function of google so it's almost definitely not accurate. |
08-28-2015, 03:21 AM | #15 |
That 100 means Honda "GCC" family (SCR100...) 50.0*52.0 ie. 81cc in GY6 (Stroke: 41.4) . Better ring is difficult to get in China.
72cc Φ47 1.0*1.0*2.0 Tons horizontal (pit bike/ cub...) also this size... Φ44 http://www.dongya.cn/prodlist.asp?page=1&tp=4&keywords= Generic GY60 is 1.0*1.0*2.0 BUT that shop IS using CB125T/CM125 (ie. those 125 twins): 1.0*1.0*2.5 instead (it MAY work...)
