Jonway BWS 50
My wife's scooter arrived yesterday. Seems like a fine little machine. The driver had to leave it at the foot of my driveway, there wasn't room enough for him to back in or turn around. I had it out of the crate and in the garage within a half hour. It was fully assembled, sans battery and mirrors which were stowed under the seat.
Now here's the funny part. I could not for the life of me figure out how to open the seat! No handle or key lock anywhere? I googled "how do I open scooter seat" and found a couple of videos. They all said to turn the key to the left and push on the seat. Well, nothing happened. I thought it might be an electric switch so I hooked up a battery out of one of my dirt bikes and tried again. My wife asked what the delay was, I told her about the seat and the instructions I got from the videos. She, who always, always, gets right and left bassackwords, turns the key to the RIGHT and the damn seat pops right open ![]() So I finished up the assembly and gave it a quick PDI and took it for a spin. It was awful slow (me being 250+pounds and it being <50CC). Nevertheless I expected more than 15MPH out of it. It started to loosen up after a few minutes though and I was able to get 25+ MPH out of it after a few heating cooling cycles. It did really great on the gravel and dirt roads, which is why I got the fat tire version in the first place. No disappointment with the ride or handling. It's rock solid on loose surfaces. Overall, I'm pleased with it for money (less than $1K delivered www.saferwholesale.com, 2 weeks from order to delivery ![]() I do, however, strongly feel that an 80CC kit is on the horizon. Sooner than later.
2000 HD XL1200C 2006 Hi-Bird QH-250-GY 2004 150CC Dual Sport (Chongqing Xgjao) 1978 Honda CB750K 1977 Honda GL-1000 (Goldwing) Project/Parts bikes 1977 Honda CB-750K 1977 Honda CB-550F Last edited by rich_e; 07-30-2015 at 01:02 PM. Reason: spelling |
Forgot to mention that I have to send for the MSO. I emailed them this morning and they replied, right away. They said one to two weeks for the MSO. So we'll see how that goes. So we're looking at a solid month from order to ready-for-registration for this distributor.
Also, if anyone has installed a "big bore kit", where'd you get it and how has it held up? Did you upgrade the head and carb as well? There are dozens of kits out there, need to narrow down the field a little bit. It's a 139QMB engine. I'm liking the products I see on http://www.scrappydogscooters.com/13...rformance.html. They "seem" to be knowledgeable. There are cheaper parts out there, but who can say if they are inferior to the "made in Taiwan" parts. I mean, the entire scooter is made in China and it's great. Why not stick with China-made parts?
2000 HD XL1200C 2006 Hi-Bird QH-250-GY 2004 150CC Dual Sport (Chongqing Xgjao) 1978 Honda CB750K 1977 Honda GL-1000 (Goldwing) Project/Parts bikes 1977 Honda CB-750K 1977 Honda CB-550F |
Downside is how the piston weight unbalances the rotational dynamics . . enhancing the odds of bearing failure.
#4 | |
I'm thinking, if more performance is really necessary, to just put in a complete 150 engine. I've already got my Craig's list search set up to notify me if any 150CC scooters are posted in my area. As Louis posted in his upgrade thread, just get an entire scooter instead of just an engine. They come up all the time for cheap without a title or wrecked.
nice looking scooter, I really like the yellow. I just emailed an add on craigslist that's not running for 100, doesn't say what it is but I'm guessing its a 50cc.
Still no MSO. I E-mailed them and they said it came in from China on Wednesday and they mailed it out to me the next day. So perhaps it will come in early next week.
I did change the man jet on it though. Went from a 79 to an 87 (smallest I had on hand). Surprisingly, it wasn't too much. Runs much better now. There's a hill near the house that it would drop down to 10MPH pulling me up. Now it can maintain 20MPH. It'll pull me up my driveway into the garage from a dead stop, something it couldn't do before. Full throttle is now useful. Before, I had to back it off from full throttle to get any RPM out of it. I didn't mess with the pilot jet or the needle. I pried the cap off where the mixture screw is supposed to be. There's just a headless plug there held on with a c-clip. No screw. Not to worried about adjusting it though. It'll spend most of its time on the main circuit (I.E. WFO!). The idle does tend to creep up a little though. I'll get it set nice and low and it'll creep up a few hundred RPM and stay there until I blip the throttle. It'll return to a low idle and start to creep up again. I double, triple, checked the intake and air box rubbers. Everything is tight. Should be better for my wife now. She hasn't ridden it much, it wasn't responsive enough when it was running so lean. She'd get it going to slow and loose her balance because it wouldn't pick up speed fast enough to maintain momentum. I also changed the break in oil and the gear oil. I know, should have done that on day one but I figured it actually needed breaking in. I only put 15 miles on it so far anyway.
I like the picture of the scooter at the end of the drive and the truck pulling away.
Yeh 250lbs is a good chunk of change for that scooter. How is the performance with your wife riding it? Should be able to hit 35mph pretty easy. / |
By the way Scrappy Dog has a very good reputation for parts and support.
I have used them with good results.
They also sometimes come restricted. Research and see if your model comes from the factory restricted. Can be as simple as a set/stop screw at the carb and I have also seen something about removing and/or replacing a bolt at the transmission to remove the restriction.
Related discussion.
Nice looking scoot! You can read about my adventures and success with getting more speed out of a 50cc four stroke here: http://www.chinariders.net/showthread.php?t=9421
#13 | |
#14 |
I don't think I'll do the big bore kit. It seems to have enough juice now with the jet change. An exhaust and air filter about the only other changes I'm considering.
#15 |
