Old 05-19-2015, 02:42 PM   #1
jimjr21   jimjr21 is offline
Valve Clearance
What clearance have you checked and set your valves to? How many miles on bike at time of service?
Factory spec is .04-.06mm.
I feel this is way too tight of clearance. Any thoughts from anyone else?
Currently In the garage in various states of running (or not) order
2015 Rx-3 super speedy blue
2003 BMW F650GS
2001 H-D V-Rod
1999 Ducati 750SS
1997 Yamaha Riva
1995 KTM 250
1970 Honda CB350
1952 Ariel Square four
Old 05-19-2015, 03:24 PM   #2
I am getting ready to check the valve lash on my RX3, but I haven't done it yet. CSC specifies the valve lash as 0.04-0.06 mm for both valves. Initially, I though this valve lash was too small for the exhaust valve. However, I am going to follow these specifications for the first few inspections/adjustments, and if the bike continues to run well, I will stick with them.
However, it is interesting to refer to the AJP PR5 Owner's Manual. The last page of the manual, page 34, lists the following specifications for valve clearance.
http://issuu.com/ajpmotos/docs/ajp_pr5_user_manual_en
Intake: 0.05 mm
Exhaust: 0.08 mm
The AJP PR5 employs the same Zongshen NC250 engine, and Delphi EFI as the Zongshen RX3.
Old 05-19-2015, 03:57 PM   #3
No1Vic   No1Vic is offline
No1Vic's Avatar
I see member Katflap set his valves to 0.06 which made the engine better especially from cold appearing to have cured cold start stalls, I'll be setting mine to this value once there's a few more miles on the bike.
2015 Honley RX3
2010 Suzuki 1250 Bandit
2006 Suzuki Hayabusa
Old 06-17-2015, 05:28 AM   #4
I have inspected, and adjusted the valve lash on my RX3. All four valves were tight. I set all of them for a clearance of 0.06 mm. The bike is running great, and I am getting about 70 mpg every time I fill the fuel tank.
Old 06-17-2015, 02:34 PM   #5
AZRider   AZRider is offline
Being very old and very conservative, I took the middle ground and set mine to 6 thou. I'm not easy on the throttle and consistently get around 70 mpg. I'm very happy.
George
2016 CanAm Spyder F3-L
Old 06-17-2015, 05:23 PM   #6
rjmorel   rjmorel is offline
rjmorel's Avatar
6 thou or .06 mm ? 6 thou = .152 mm .002 thou = .06mm Not picking on you AZ but just saw Spud did his at .06mm and yours is 3 times more clearance. ????? I can here your valves clattering clear over here but then noisy valves are happy valves I've been told. )) rj
Old 06-18-2015, 12:33 AM   #7
Being old school British I have a hard time accepting the metric system and still mix up the terminology. You'd think that after almost 40 years in the States I'd have it down by now. You're absolutely right, l should have written mm, my bad. Fortunately, my feeler guages are smarter than me and it all worked well in the end.
George
Old 06-18-2015, 02:04 AM   #8
You'd be downright confused as a Canadian. We're officially metric, but so much is still expressed in either US or Imperial.
Old 06-19-2015, 06:42 AM   #9
KirkN   KirkN is offline
It's: SLAPPY valves are happy valves!
My pushrod 250 called for 0.002" intake and exhaust. I couldn't bring myself to do only 0.002" on the exhaust. I went with 0.003" intake and 0.004" exhaust.
