lifan 200 engine problems
I did the c clip mod and then changed it back. Now bike wont start without choke and when im ridding down the road it will go fine for a bit then start bogging down and back firing a little. Any help is appreciated.
The c-clip will only affect mid-range, not starting or idle. If the bike would start without the choke before and now it won't, I'd check the slow jet; maybe it's a little clogged.
Did you make any other changes?
No other changes i figured it was clogged or something thanks alot
