01-27-2015, 06:04 PM | #1 |
help identifying atv
hope you can see these as im not very goodwith computers |
01-27-2015, 06:08 PM | #2 |
other things that may help is engine says 167ml on it and vin says its 2005 from china (asia)
01-27-2015, 08:42 PM | #3 |
Welcome!
Please show us a pic of the engine and the rear axle.
01-28-2015, 12:03 AM | #4 |
The neutral reverse indicator cover is on upside down.
Same part as my sunL though |
01-28-2015, 11:38 AM | #5 |
01-28-2015, 11:57 AM | #6 |
one of my main problems im haveing is i cant get starter motor reduction gear to fit in the large gear is to big probs last owner didn't fit the right part
01-28-2015, 02:12 PM | #7 |
Water cooled CG250 motor. Try searching eBay for CG250, and see what comes up.
01-28-2015, 03:54 PM | #8 |
thank you and for my next question if thats ok i need a new reduction gear i think it is called as my starter didnt work so i bought a 9tooth starer motor but now my reduction gear wont fit and the bearings are missing on the gear
01-28-2015, 05:08 PM | #9 |
Std CG 200 &+ uses 11T starter motor ...
http://mall.mxjidian.com/?de=goodsdetail,gid--100027
01-29-2015, 06:29 AM | #10 |
I Need a new reduction gear all ready nought a new 9t starter motor
01-29-2015, 07:35 AM | #11 |
only problem is i live in uk so cant find supplyer
01-29-2015, 04:01 PM | #12 |
There's supplier in UK, 18/62 is a standard CG125 parts.
Worst case can bought from China. http://item.taobao.com/item.htm?id=26437344913
01-29-2015, 04:27 PM | #13 |
Hello thanks for your help what starter motor should I use on that set up 9t or 11t ?
01-29-2015, 04:30 PM | #14 |
Std CG125 is 9T http://mall.mxjidian.com/?de=goodsdetail,gid--100054
01-29-2015, 08:00 PM | #15 |
Hi thanks that's what I bought so once my gear is here I can get quad running and then rebuild her to her formal glory I hope
