Old 01-01-2015, 08:11 PM   #1
Nydirtbike   Nydirtbike is offline
Head Scratching Help with agb 36 apollo 250 dirtbike
Hi guys I'm new here. Just got my apollo 250cc dirt bike in. So far so good.
Bike is quick looks good but I will be doing mostly trail rides so I would like to get new sprockets and maybe a exhaust system.
Anyone know about after market parts I can get and where?
What parts are compatible with this bike?
Thank you
Old 01-01-2015, 10:56 PM   #2
Welcome!
Please start by showing us pics of your new bike.
Old 01-02-2015, 08:59 PM   #3
pic
here it is
Old 06-04-2016, 03:23 AM   #4
buffsurfer1   buffsurfer1 is offline
Where, How much, Etc
Originally Posted by Nydirtbike View Post
here it is
Sweet looking bike. Pure off road. Just what I have been looking for.
Would you mind telling me where you got it and how much you got it for?
I assume you are in NY. I'm in CT so shipping would probably be comparable.
How has the bike been doing since you bought it? You have about a year on it now haven't you?
gerrybc@msn.com
Old 06-11-2016, 10:29 AM   #5
Dtimes55   Dtimes55 is offline
Doh! new Apollo 250cc
Just bought a Apollo 250 today ..someone suggested I change spark to NGK... But NGK what size numbers what????
Old 06-12-2016, 05:42 PM   #6
humanbeing's Avatar
http://www.chinariders.net/showthread.php?t=14251DPR8EA-9[4929] is the stock in Honda BUT DR8EA/ D8EA also works...
Old 01-03-2015, 01:48 PM   #7
Sweet bike! If you give us a close-up shot of the engine, we can tell you which type you have.
Remove the rear wheel, remove the sprocket and measure it. You'll need to know the number of bolts holding the sprocket, the bolt circle and the hole size. From there, we can hopefully guide you. Measure the distance between the pins of the chain.
Tires, chains, fuel filters, clutch cables, etc are easily found at www.rockymountainatvmc.com or www.bikebandit.com
Old 01-03-2015, 04:08 PM   #8
Size
Ok I'll take a pic when I get home.
I have the Manuel for the bike and it says that it's a 530 58mm 37t 4 bolt
Ill also check those website out. I want more torque bc I do mostly trail rides.
How big of a rear sprocket should I go
Old 01-04-2015, 12:27 PM   #9
If you had a 50 on the rear wheel and a 12 on the countershaft, you could climb anything you point it at.
It's important to know what 58mm means. It is likely to be the center hole, but it still doesn't tell you the bolt circle. JT will need that info.
Old 01-04-2015, 10:49 PM   #10
they still haven't got back to me.
yes 58mm is the center hole. Its a 37 tooth in rear and 14 in front.
Can i just drop the front down to a 12? Do i need to touch the rear?
Old 01-03-2015, 05:01 PM   #11
humanbeing's Avatar
Find it in http://www.jtsprockets.com/catalogue OR ask them http://www.jtsprockets.com/contact
Old 01-03-2015, 05:19 PM   #12
ok contacted them hopefully they can help.
Old 01-05-2015, 01:27 AM   #13
Yes, you can just drop it down to 12, but don't go any smaller. You might need to pull a link from the chain, but hopefully not.
Old 01-05-2015, 02:18 PM   #14
KirkN   KirkN is offline
Looks sweet. Same basic bike as my own Baja 250 (posted pix in New Member Intros). I like mine a lot. But even shorter gearing? Wow, you must really want to scale cliffs. Mine is already geared so short it tops out at about 40 mph, wound out in 5th. 2nd gear is still just about walking speed...
Exhaust system? For more power? Or just more noise? Does the stocker come with an integral spark arrestor? Mine did.
Anyway, enjoy it and welcome aboard, from one newb to another!
Old 01-05-2015, 07:12 PM   #15
the bike as is has not much pull.
i do a lot of trail rides in the catskill so speed isn't my thing.
Exhaust would be great but i can't find a after market that will fit. Any suggestion?
Beside the shorter gearing you think i will gain some good torque?
Happy for all the help everyone is giving me
