Dave_D solved the bumpsteer problem!
Dave is the man!
![]() For the unfamiliar, bumpsteer is when a wheel hits a bump and changes direction in the process. The wheel should remain straight throughout the range of suspension articulation, but it's not always like that in the real world (cars and trucks included). It usually results from a tie rod that is a dissimilar length to the control arm, but it can also be due to a dissimilar angle, as Dave pointed out. Read his thread here. To complement his thread, I took pics of the tire from the top view (before and after) to show just how dramatic the difference is. This is the wheel unloaded, with the front of the quad on a jackstand. Even at full droop, the wheel remains straight. This is before I moved the tie rod. ![]() When you jack the wheel up, this is what it does. ![]() You can see how much the wheel turns to the left when the shock is compressed. To be clear, the handlebars are still pointed straight ahead! ![]() One end of the tie rod was upside down, so I removed it and placed both tie rod ends upside down. The gives the tie rod the best clearance all around. This is the newly-corrected tie rod. ![]() This is the front wheel at full compression; you can see that it still points straight ahead. ![]() After I got the tie rods sorted, I set the front wheels to about 1/8" of toe, and called it done. Thanks Dave! ![]()
Looks good
Glad to see some before and after pics as I forgot to take them What a difference Dave |
I forgot to take pics of the tie rod before, because I was focused on the amount of steering angle at full compression. It's severe.
Thanks again! ![]()
I did take note of dave's thread and had a look at all of ours and they are all mounted from the top.
thanks Dave and Weld.
I could be wrong......it has been known to happen<div><br /></div><div>core directive 172: No member of the core shall report for duty wearing a ginger toupee</div> |
Midlife, are they mounted from the top on both the inner and outer?
yes they are....all of them all atv's
You're lucky. I've had my 150 since 2007, and it was only recently that Dave figured it out for me.
