Old 07-23-2014, 04:18 PM   #1
mmprestine   mmprestine is offline
Tmec-200
HI guys! New here, well kind of as I joined years ago after getting the kids some chinese atvs. Sure reminded me of the good old days with the mini-bikes, dirt bikes, and 3-wheelers. Countless hours on the paper routes to get toys, the kids of today just have no clue.
Anyway purchased a TMEC-200 from Mefast last November and now just getting to posting here. The delivery was drop shipped direct from Wade @ xcalibur motorsports. Everything was recieved and went together as expected. Just the normal Chinese bike crap that I had to deal with like plastic fitment, shoddy bolts, welds, etc. This post will not be about setup just my ramblings of ownership and what I have done to make it how I want it. I have owned motorcycles my whole life and no matter the manufacture and type there still are things I always seem to do to make it mine. I now have about ~600 miles on the bike of on and off road.
Now for some pics
Matt
Old 07-23-2014, 04:28 PM   #2
TMEC-200 Mod 1
I choose to leave the passenger pegs off as I never plan to carry one on this bike and truthfully I dont feel the bike is really built for it.
Old 07-23-2014, 04:34 PM   #3
TMEC-200 Mod 2
Removed all the epa carb crap, built a block off plate and used a vacuum plug on the carb intake. The engine is now about 35% quieter and the odd valve noise is now gone. Engine runs cooler and has more power throughout the rpm range.
Old 07-23-2014, 04:36 PM   #4
TMEC-200 Mod 3
Removed the low hanging reflector. I cut off the lic plate holder, looks much better now.
Old 07-23-2014, 04:38 PM   #5
TMEC-200 Mod 4
Removed the squishy chinese rubber chain guide roller. I turned a black acetal replacement on the lathe that will last a life time.
Old 07-23-2014, 04:40 PM   #6
TMEC-200 Mod 5
The side faring connecting rod does not line up with the bolting hole. I need to cut the tab off and reweld but for now I just did this.
Old 07-24-2014, 08:27 AM   #7
For those who don't have access to a lathe, perhaps one of these chain rollers will work as well.
http://www.rockymountainatvmc.com/p/...chain%20roller
Old 07-26-2014, 03:54 PM   #8
footer   footer is offline
going to have questions on this, but first ill ask a friend who is going to help me do it if it makes sense to him…
and i just put tape over the beeper for now, much quieter!! thanks for that tip!! ill be getting those fort pegs too, and should go look at my chain roller now while I'm thinking about it. this site is the best!!
Old 07-26-2014, 06:54 PM   #9
These tips are great! I personally like the noisy turn signals simply because I am one of those types that forgets to cancel the signal and will ride for miles with my signal flashing. But I have been contemplating getting rid of the alien-to-me EPA smog crap that was forced on the '13 and '14 TMEC models.
I definitely need something for my chain because my chain rubs the rubber guide due to my smaller rear sprocket. I am hoping that Wade will convince the TMEC factory to start using 46 tooth rear sprockets as I have suggested to him numerous times. But they would definitely need to figure out a fix for the chain guide if they do that (or if Wade finds a manufacturer to make a 46 tooth rear with this bolt pattern in steel as an aftermarket option).
Speaking of rear sprockets, Rebel Gears of Tennessee (I think of Tenn, but they are on the internet) do have the TMEC bolt pattern when I had them make me a 40 tooth, but if you want to have them custom make you one, get at least a 44 in my opinion. But, keep in mind, they make them in an alloy since they are technically made for competition, and I went through a few chains on my commutes since the alloy ate them up (I did not realize people who compete in motocross and such will buy a chain just to use for a race or two, so that kind of made me realize that my sprocket had nothing necessarily wrong with it, as well as my chains, but the sprocket was not made for commuting like the stock 56 or the steel 48 I found in the UK via JT Sprockets (I guess you can order the 48 via JT's US affiliate, but it was easier and less cost to use an online parts retailer in the UK who carried them).
http://www.urbanbike.co.uk/
http://www.rebelgears.com/
Old 07-26-2014, 07:39 PM   #10
Let it breathe
I know that some of these mods are to much for some but I will capture them anyway. Here I modded the exhaust to remove the catalatic honey comb to allow the exhaust to breathe more. Cut it, Dig it, Tig it!
Matt
Old 07-26-2014, 07:55 PM   #11
How much does Reble Gears charge for a custom made sprocket?
It seems unclear to me how the alloy would devour the chains. Was the actual pitch of the teeth correct? Perhaps the engagement was to deep for the type of chain roller that was used? These are all just questions. I have been looking around for some cheap plate sprockets that I can tailor to the bolt pattern of the TMEC. I have a small CNC at home that I could cut some customs but starting with the plate sprockets is very cheap and then I just need to mill the bolt pattern. I was also looking at Honda and Yamaha sprockets also but just haven't pursued it very hard.
Old 07-26-2014, 08:09 PM   #12
[QUOTE=culcune;169985]These tips are great! I personally like the noisy turn signals simply because I am one of those types that forgets to cancel the signal and will ride for miles with my signal flashing. But I have been contemplating getting rid of the alien-to-me EPA smog crap that was forced on the '13 and '14 TMEC models.
yes i think i would forget the blinker too, thats why i just put tape over it for now. not nearly as embarrassing when sitting at a stop light and having people stare… loud enough to hear, but not from a block away!
the exhaust looks simple enough too, have a friend thats a big welder. any pics on what you did to take that other piece off by the spark plug? i kinda looked at it, and ill have to have someone do that for me I'm sure. i see the plate you have on it now where mine has a tube going up into the bike somewhere.
i don't think ill have to do anything with my sprockets, i can get up to 60 real easy and still have throttle left to use. unless I'm missing something about the advantages of different size sprockets. haven't tried to get a top speed yet, being a new engine and all…
I've had a few guys give me the business for buying chinese - until they check it out. now they are jealous! they all say its a fine bike! of coarse they all say 'until you need parts' but with you guys, I'm not worried at all!!
Old 07-29-2014, 11:42 PM   #13
tankme   tankme is offline
tankme's Avatar
What did you make the block off plate from? What thickness is that? I have this tube removal to do as well.
Thanks!
Jim
2008 Zongshen 200GY-A, HS163FML : Needs: Battery, Battery Box, Both clutch and brake handles, exhaust system, all plastics, gas cap, starter rewired. Her name will be Phoenix.
2007 Shineray Speedee 150, 1P57QMJ: Needs: starter rewired, exhaust connected, cleaned up, ignition switch simplified, new seat and lights, new front and back racks.
There's no such thing as a free puppy or motorcycle. I think I have caught the fever from y'all.
Old 07-30-2014, 08:37 AM   #14
bogieboy's Avatar
Thanks!
Jim
on mine i used a cuttoff wheel to crop the tube just above the plate and welded it shut... just has a cute little nub left now...LOL
Old 07-30-2014, 01:37 PM   #15
tankme's Avatar
Thanks for the tip! I'm doing something on it today and it'll be plugged by the time I'm through.
Thanks all,
Jim
163fml, 200cc, tmec, tmec-200, tmec-200-1
