Old 07-28-2013, 03:47 PM   #1
TheAntiBody   TheAntiBody is offline
Weird situation
Hello everyone ,
I have a gio 250cc ,x31, 2007
Well the bike always overheated ,
I checked yesterday the oil and yes, it was black and burned.
So I replaced the oil ( 1 liter )
And now when I want to start it doesn't let me .
Nothing wrong with the air filter , I just replaced for brand new one.
the carb is fine , I cleaned at on the morning .
I guess the plug is weak or maybe doesn't work , am I right?
But if its true , so how that can happen , when changing oil it's tuff for the plug to start the engine ?
Thank you!
Old 07-29-2013, 01:34 AM   #2
Is it still using the stock plug? If so, try an NGK D8EA. They're cheap.
Old 07-29-2013, 11:42 PM   #3
Actually what a coincidence , i bought the same spark plug .
But i found what that is not the spark plug it self.
when i changed the oil i guess i overfilled oil .
1 put 1 liter of 10w40 inside , and it was a way more then the high mark.
Well while I'm trying to start the engine when i push the kick start , it seems that it's going almost with no Resistance, and that why the spark plug doesn't work.
Over filled oil can cause any damage?
Well if that is the problem , how i can fix it ?
Another question please : i didn't changed the oil for a while and it was black and burned , that is the reason why the engine + the exhaust were so hot ? less then 5 min and it start to melt everything around.
thank you !
Old 07-29-2013, 10:17 PM   #4
Ranger0793   Ranger0793 is offline
Fuel compression and spark is what you need. If you are sure you have fuel and compression then spark may be your issue. A new plug is probably your easiest option.
